Old 02-13-2007, 04:44 PM
Steve Barcak's Avatar
Which shroud are you using Jeff? A big block or a small block? They are different. Mine is a big block and my shroud is damaged. They are discountinued from GM. Will I need a Bb or SB shroud? Also, do you have a more of a side view photo that may show the fan/shroud better?
Thanks,
Steve Barcak www.pontiacheaven.org
"Real Pontiacs only.....no corporate nonsense!"
Hundreds of Pontiacs in Az
Facebook- Pontiac Heaven
Hosting-
Phil 2:11
Old 02-13-2007, 09:00 PM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Steve, here's the pics. If I remember correctly it's a diesel shroud as that is what was in there before. But I didn't use the diesel radiator. The BB shroud would probably be your best bet since I think the BB is closer in length to a Pontiac.
ID:	82569   Click image for larger version
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
Old 06-29-2007, 04:24 AM
Pontirag Pontirag is offline
Default 1957 GMC V8/hydro
last run in 1977, parked because the tranny slipped.
Old 06-29-2007, 09:24 AM
Bill Hanlon's Avatar
GMC Hood Birds in that condition are going for ~ $250 on ePay.
Old 06-29-2007, 12:42 PM
Bill Eveland's Avatar
Those lights on the roof look like a pair of nipples.
Not a bad looking truck though.
Illinois Outlaw Gassers
6.27@107
9.97@131
Old 06-29-2007, 01:28 PM
In cold weather too.
Was that hood ornament an option? I have seen a few GMC's that vintage, but never with the hood ornament.
Old 06-29-2007, 04:08 PM
Yes, the hood ornament was an option. My truck had one, but I chose not to put it back on when I painted the truck. It is pitted and needs replating. Still have it up in the garage attic.
Old 06-29-2007, 05:25 PM
Hydromatic slipping, 1500-2000? to rebuild . Unless you can find a good used one. I think Bill Hanlon was just looking for one for his truck.
If you didn't care about originality on the trans , adapter kits are available for th350/400. about 600? for the adapter kit.
6.27@107
9.97@131
Old 06-30-2007, 01:06 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Pontirag- Any plans for the GMC? I hope you've kept the engine 'alive' the last twenty years.
Old 06-30-2007, 01:51 AM
amcmike's Avatar
amcmike amcmike is offline
You guys have to stop this thread. I'm starting to get an itch I can't afford to scratch!
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 06-30-2007, 04:31 AM
Tried to sell it several times on ebay. lots of jerks out there.
Old 06-30-2007, 09:38 PM
Originally Posted by Pontirag
Anybody know if those cab lites in the corners are factory.
My 55-60 GMC Master Parts Book has an accessories section that shows lots of "clearance" lights including some that mount on the to of the cab.
Went shoping for brake booster and powersteering. Couldnt find any.
You didn't look in the right place. Pick up a copy of Custom Classic Trucks at a big book store (Border's, Barnes & Noble, etc.) and look through the ads. There are tons of power steering options from original type ( http://www.classicperform.com/power1.html ), 70-80 GM 800 series box (I have one on mine) to a rack and pinion rig that mounts on the back side of the stock straight axle (came out about a month after I did mine, wish I would have waited).
There are also many places selling dual chamber master cylinder kits, both with and without a 7" booster. Space is a little tight to mount the power unit under the floorboard in the stock position if you have a standard transmission because the cluth pedal linkage likes to live in that same space, but with an automatic there is plenty of room. I have a dual master cylinder kit on mine, but chose not to use a power unit. Pedal pressure is fine. Make sure you specify the type of brakes you are using, drum/drum, disk/drum or disk/disk. Mine is disk/drum.
[/QUOTE]
Only auto parts store in town had an oilfilter sitting on the shelf PN 85121. nine bucks after tax.
That was one reason I took off my filter mount and replaced it with a filter mount from a '77.
Old 07-01-2007, 04:23 PM
I think my running lites are origional because of the wiring.
Old 06-20-2008, 12:27 AM
pontiacpark pontiacpark is offline
Cool v8 gmc
my name is dave roper. i reside in new zealand and have an original 1957 347 pontiac powered GMC, half ton truck. trans is a hydromatic. i was talking with steve from pontiac heaven and he sugested this site. i am looking to purchase the emblems on the guards and doors for this truck. dont seem to be able to get repros. any ideas guys.?
I also own a 1960 2 door bonneville.
both vehicles were sourced from your country. New zealand has a large following of people keen on american cars. the same cars in the same era were imported from canada. they are right hand drive. the dash, gauges, and other minor details on the canadian cars are different than the same american models.
best for now
Old 06-20-2008, 01:36 AM
I recomend Oldgmctruck.com. Some real stand up guys there. Boy do they know their stuff.
Would be very curious to see throttle bracket arrangment on a right hand driver.
You talkin about the actual "hydramatic" chrome badges on the fenders and the guards behind thedoor handles?
Hydro chrome is hard to find. some low quality repro stuff was available a few years ago but dont think so now. The door guards are available just about every where.
I like Classic Parts of America ar ClassicParts.com
Old 06-20-2008, 03:15 AM
Originally Posted by pontiacpark View Post
... have an original 1957 347 pontiac powered GMC...
Pictures? We all love pictures!
(My GMC is a '59, but it's all apart right now)
Old 06-20-2008, 04:27 AM
hi guys, sorry i posted this in a different page so here goes again. i live in new zealand. i have an original 1957 v8 pontiac powered half ton truck. m a pontiac fan so a pontiac powered truck fits in with my other pontiac car. it is a 1960 2 door bonneville coupe. it is a tri power ,4 speed manual car. both vehicles were imported from your country
  #38
Old 06-20-2008, 04:39 AM
thanks for the info on parts for this truck. will try the sites you have put foward. the RHD thottles were a hassle after a few years. brackets were attached to the firewall. a linkage system connected thru these brackets and on to the carb. they got sloppy over time and most of us changed to a adapted thottle cable. we did seem to get some different engine combos from canada. it seems that whatever engine and trans available at the time were put in. mostly 283 chev but some "oddball" combos as well
  #39
Old 06-20-2008, 08:29 AM
Are you looking for the "Hydra-Matic" badge that mounts under the GMC badge on the fender? If so, I have ONE that is real nice, may be NOS. It is black background. Interested?
  #40
Old 06-22-2008, 03:01 AM
thanks for that info Bill. i am interested . mine is red but i can fix that. i have sent an email to you. if i can get a contact for you my friend in portland will contact you for price and arrange shipping. best for now
