Transmission O\D Question
Would 68 mph at 2000 rpm's be to low for running a car with a\c and in o\d? The engine I plan on having is a 461.
My 99 Jeep Wrangler turns about that in OD with the ac on with a 4.0 6 cylinder, so I'd say you're going to be fine. BTW, the jeep weighs about 4000 lbs and will have WAY worse aerodynamics than any Pontiac. The key here is to make sure that the torque converter is coupled at that speed unless you have a lockup converter. Of course a stick throws that all out the window.
"We used to laugh at Grandpa when he'd head off and go fishing. But we wouldn't be laughing that evening when he'd come back with some whore he picked up in town." ~ Jack Handy Last edited by Grant Miller; 04-24-2008 at 03:52 PM. |
It will depend on the cam, compression ratio, and carb of your engine.
With all the torque on tap with a pontiac engine and it being a 461 assuming a reasonable streetable cam I think 2000 at 68mph will easily work. My 400 TA with an OD 700R4 & 3.08 & 27" tires cruises at the following RPM/Gears 3rd = ~2000 rpm at 50 mph with manifold vac 15" to 22" 4th = ~1800 rpm at 70 mph with manifold vac 10" to 15" I will be changing gears to a 3.42 to bump my 70 mph cruise up to about 2k.
1977 TA 400 9.5:1 CR 351hp 414LbFt, #13 Heads + 1.52 Roller rockers, 1968 Pontiac 400 intake, Holley 4165 650 DP #7054 Howards Hyd .447/.467 IN:288 EX:298 214/224@.050, MSD6A + MSD timing control + H2o/Meth 1-5/8" headers, Magnaflow 200CPI Cats + 2.5" Pypes X, Dynomax STs, TH-700R4 2200 stall, 3.42 Eaton 10-bolt, PS/PB/PW/PL/AC/Cruise 13.84@100.14mph 2.18 60' on P255-60-R15 radials, pump gas, mpg : 21.5 hwy 15.2 city |
I am not cam expert, but I think a .47 - .50 lift with 235 - 245 duration @ 050 would be streetable in a 455 or larger. Choose the lower lift/dur if its a daily driver. "streetable" is subjective, to me it means plenty of low-end and mid-range torque down to 1200 rpm. Has good vacuum signal for good power brakes. Overall well behaved in traffic including extreeme heat or cold conditions. This means that the intake and carb need to complement the cam and be sized for the intended use. Two reasons I am changing gears to bump up the cruise rpm: 1. Improve performance, esp low end in the first 0-300 feet. 2. Engine seems happier at ~2000 vs ~1800. I know it doesnt sound like much but, keeping the manifold vacuum in the 15" to 20" (on my engine) means less throttle and better fuel atomization which means better gas mileage. Or at the very least no loss of mileage but gains more cruise driveability.
I'm predicting little or no change with the gear swap ( you already have a 3.06 first gear with that 700-R4) and more traction issues out of the hole.
Also, if you are changing the gears, why not put a limited slip in there while it is apart?
___________________________________ "Objects in mirror are closer than they appear" |
Seriously, you think little to be gained in performance and adding traction problems to boot? You are right about the 3.06 1st gear, its like a th350 w/ 3.74 gears. If I go with a set of 3.42s it would be same as a th350 with 4.15 gears (at least in 1st gear). Does seem a little steep on street radials without any other traction devices......I dont want to sit an spin
