HEI Connector Plug
Where can I buy the connector plug needed to plug into a HEI distributor. This is the 3 pin plug I need to splice into the wiring harness side.
Thanks. |
The connector going into my HEI is two pin, one for power in, the other output to tach. Mine is from a '77 400, but I think all are the same until computers got involved.
Summit/Jegs has HEI pigtails about 7 bucks?
lacking a proper plug I have just used an ordinary spade connector for the power and tach wires. |
Main harness from distributor TO cap/coil has three terminals.
It used to be a part store item, hadn't checked in awhile. Some came with radio capacitor attached and they do come in different lengths depending on application; Pontiac, olds, buick, chevy, caddy,etc. and 4,6, or 8 cylinders. |
