Old 05-13-2009, 04:55 PM
Fat Cat's Avatar
Fat Cat Fat Cat is offline
Default Adding a circuit to Fuse Block
I'm installing some power seats in my '66 and need to power them through a 20A circuit. As I was looking around under the dash, I noticed there's a slot open on the fuse block which I could use for doing this. However the only problem is there isn't a connector on the one side for the fuse to sit in opposite the side of the bus bar. It appears to be a special deal too since it's a double crimp with the fuse holder. I've looked around and tried calling these Auto Harness companies, and no one is willing to just sell the connector I need for the other side without selling me an entire harness which I'm not looking to do just yet. Any suggestions on this or am I SOL? I can always tap in power somewhere else and use an inline fuse, but i like to keep my wiring as factory fit as possible. Thanks.
"A bend in the road isn't the end of the road unless you fail to make the turn."
Old 05-13-2009, 08:52 PM
R68GTO's Avatar
R68GTO R68GTO is offline
I had a similar situation and ended up buying a POS fuse block off e-bay and robbed the connector I needed out of it and put it where I needed it.
R68GTO
1969 Camaro COPO 427 "RAT'S NEST"
Old 05-13-2009, 09:01 PM
paint guy paint guy is offline
Have you tried either TerminalSupplyCo.com(they have a store in New Brighton)or Scheleen-gray auto electric in St.Paul?Either one MAY be able to help.
