horn relay
Does anyone have a close up picture of the wire placement for a horn relay for a 67 GTO? My horn relay went bad and I initially bought another one from a parts store that had a different wire connector. I took the wires out of the original plug and attempted to hook up the aftermarket relay. It didn't work. I then order the right relay from PY and want to make sure it gets hooked up properly. If it still doesnt work, does anyone have any trouble shooting tips? Thanks.
horn relay
ANYBODY?????
how many pins do they 67 relay have on them? I rewired my 70. If there are 3 pins,one goes to horn button,one to horns,one to positive.You should be able to figure out the hot wire,and the horn wire under the hood. I would look online at pictures of horn relays wired on a 1967 GTO so you know what color wires go were.
horn relay
Mine has three wires. The problem is I don't know what colors go where on the relay. I need a picture....
horn relay
don't the wires have special female ends on them? hey try this site there is a picture of a 65 relay on one of the guys threads.if you know where the hot wire goes you could figure the other two out..http://www.gtoforum.com/f12/need-qui...80/index2.html
