Heres a wild one...69 GTO turn signals
69 GTO
No turn signals front or rear Tail lights and brake lights all work properly Front park lights and marker lights work. Turn on 4 way flashers and rear lights flash, but nothing in the front. Have checked all the bulbs and flashers... all good Any Ideas ????? |
Several ideas
Just not sure where to start.
Is turnsignal fuse and flasher good? Check both sides of fuse with test light and swap hazard flasher with turn flasher to test them. Does the turn signal cancel out the coresponding brake light? If not turn signal switch has something wrong with it. Can get you some directions together for checking wiring out at turn signal connector if you need it. |
Bad ground.
Anytime I ask the electrical guys about a weird problem they always say "bad ground". And they are almost always right....
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
