Old 09-23-2009, 09:31 AM
jbranontn jbranontn is offline
Default Headlight Problem on 66 Pontiac Tempest
Replaced headlight switch....I have tail lights , but headlights don't come on...what could be the problem....Brake lights and blinkers work fine.....
Old 09-23-2009, 09:46 AM
HJones1313's Avatar
HJones1313 HJones1313 is offline
Send a message via Yahoo to HJones1313
Check for power and ground at the headlights first. All you did was change the switch? Possible that a terminal on the switch plug came loose. Check for this by removing the switch with plug attached, then you can see it a lot easier.
"GTO......Gas, Tires and Overdraft"!
'70 GTO convertible, 434, 4-speed
Old 09-27-2009, 03:41 PM
Rapdron's Avatar
Rapdron Rapdron is offline
Thumbs up Headlights
Try your floor mounted dimmer switch.
Another Red Light Nightmare
1966 Martinique Bronze 2+2 428 tri-power auto, black top & bucket seat interior, pass recliner, ATC, Cruise, AM FM, Reverb, Wood wheel, tilt, ps, pb, pw
1966 Catalina, Barrier blue with a white vinyl top, tilt, AC, ps, pb, bucket seats with console 68 428 4 bolt, 4 speed M20 and a 66 tri-power project.
Semper Fi
Old 09-27-2009, 03:53 PM
stevep's Avatar
stevep stevep is offline
Did the headlights work before you changed then switch?
