Power Booster to Firewall Seals:
On a second generation Firebird, what goes between the firewall and the brake booster, other than the clear plastic sleeve????
Call the "Right Stuff" in Ohio, they produce all the brake kits for our cars, they will have what you need. Their number is as follows: 1-800-405-2000. Dave is the owner.
Tim john--- |
That was all I saw when I pulled mine off to go to the Hydro-Boost. Just the plastic sleeve. When I put the H-B on I used a bead of dum-dum outside all the mounting points to seal it from water infiltration. FWIW, Stewart
1976 TA, nose converted to 1970 style, 406, ported #13 Heads, '70 iron intake without crossovers, Q-Jet - Cliff style, RARE OS manifolds, Pypes duals w/crossflow, UD 230/238 custom HR 4/7 swap cam with solid roller lifters , Hydro-Boost 4-wheel discs, 4 Speed, 3.23 posi. “Nothing in life is so exhilarating as to be shot at without result.” - Winston Churchill |
Thanks Guys!
