Old 01-06-2010, 03:13 PM
snakepitt1's Avatar
snakepitt1 snakepitt1 is offline
Send a message via AIM to snakepitt1
Default Hood tach electrical connection help
I have mounted a new reproduction Pontiac hood tach to my 68. My ignition system consists of a MSD billet Pontiac distributor, blaster 2 coil and MSD6A ignition box. Right now the wires from the hood tach just hang free unconnected. Does anyone know how these wires connect to the MSD6A ignition or coil?
My home e-mail is snakepitt1@aol.com
Thanks,
Scott
1968 Pontiac Firebird convertible, 400, Ram Air 3 heads, rebuilt TH350 transmission, balanced driveshaft, H-beam rods, forged pistons, Edelbrock performer cam, intake and 750 carb, new top, new interior, powdercoated frame, stripped and painted underbody, front disc brakes, complete MSD ignition. Hotchkis sub frame connectors. All this because I wanted a 4 barrel carb!
Old 01-06-2010, 03:19 PM
HO 67 BIRD's Avatar
HO 67 BIRD HO 67 BIRD is offline
you should see a terminal on the side of the msd box for your tac.You can not hook up any other wires on the coil besides the 2 wires from your box.
SEVEN UPS 2.0 TAKING THE THIRD DEGREE ONE STEP FURTHER
2016 1/8 MILE 7.0 @ 100 MPH 406 B&M MINI BLOWER
Old 01-06-2010, 07:33 PM
428RA4's Avatar
428RA4 428RA4 is offline
Make sure the tach has the ability to take a transistorized signal, which I think the repops do, but double check. You could smoke the hood tach if not.
Old 01-10-2010, 02:37 AM
mrjestro's Avatar
mrjestro mrjestro is offline
Maybe this will help you with the tach....I run all MSD ignition, 6AL, Pro billet distributor and a blaster coil....I used an MSD tach adapter. Also check out the MSD website, they have a schematic for almost every configuration. Here is a link. http://www.msdpowersports.com/pdf/frm22049_pn8920.pdf Hope that helps.
