Old 04-12-2010, 07:37 PM
RandyW's Avatar
RandyW RandyW is offline
Default '75 Formula with tilt column problem
I have a '75 Formula with tilt column, I took the Formula wheel off to refurbish it and installed a standard Firebird 2 spoke wheel. Since I did, I have a tight spot at 12 O'clock on every revolution and driving down the road straight. Is there a spacer or spring that should go behind this wheel vs the Formula wheel?
Randy W 1975 Firebird third owner. 1980 Grand Am/black/beaurdeaux/45000 mile original owner.(Now belongs to Iowapub.) '67 Impala SS (sold)
Old 04-12-2010, 11:00 PM
GStage1's Avatar
GStage1 GStage1 is offline
Take the wheel off and check for rub marks where the upper collar is contacting the steering wheel...more than likely, you have a bent/warped steering wheel.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 04-13-2010, 07:48 AM
RandyW's Avatar
I'll look at that, this wheel worked fine on a standard column on another setup, but you never know. One thing for sure, something's wrong! Thanks.
Old 04-16-2010, 08:06 AM
RandyW's Avatar
Fixed it, machined a thin spacer to put on before the wheel, works fine.
