th400 help help switch pitch
i have a switch pitch kenne-bell trans, and need parts..where to go now?..all the old sources seem to be gone..help help..
Hey TIN TIGR,
Did you try checking with Mondello ?
Knock Knock Knockin' on 11's Door '70 Judge, Palladium Silver w/Red Interior Powered by SD Performance, Ported 6X Heads 501 HP, 554 ft lbs TQ 12.14 ET @ 114 MPH , Supercase Muncie M22, 3:55 Suspension: HO Racing, BMR< Sykorat, and Bilsteins Narrowed 12 bolt , 16x8 VintageWheel Works, Comp T/As on street, MT Drag Radials @ Strip http://www.sdperformance.com/custome...1.php?carID=42 |
some info here http://www.hotrodhomepage.com/hrhp/2...the-overdrive/ http://www.442.com/oldsfaq/oftsp.htm http://www.bdub.net/tranny/DualPurpo...dding-text.pdf Other than input shaft pump and convertor they are pretty much standard t400 stuff. As far as convertors go you might want to talk with TSI and see if they might be willing to make you a good one. Dont know if they ever tackled SP before but they make good stuff. Good luck |
There is a company in El Paso, TX that manufactures switch pitch torque converters. Had one in my '65 GTO a few years ago.
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
What parts do you need?
The difference between inlaws and outlaws? Outlaws are wanted |
I gots a running SW-Pi TH400.
What part(s) do you think you need? check CKperformance for the Converter. |
I'm familiar with the SP setups.
I have some contacts for parts. The biggest issue these days is finding the solenoids. PAE in El Paso no longer exists.
www.jakesperformance.com Racing Automatics and LSx Engine components |
thanks guys..all will get replys..i looked up all the "olds" sources, and nobody there..wtf..what happened to america?
they went into nowadays fad LS chit
someone who thinks logically is a nice contrast to the real world. http://www.youtube.com/watch?v=3FfKVVZW1-Y |
called ya jake..
is this what were looking for ?
the last one in the planet
