Electronic Distributor Conversion Kits ??
Has anyone used one of the PerTronix IgnitorŪ Solid-State Ignition Systems? I am thinking about buying one for my 62 Tempest. I am in the process of a complete re-wire of the car. I know that the original wiring had a resistor wire going to the coil. All of the original wiring has been removed. My options are to use a ceramic resistor and keep the points distributor, or update to the electronic conversion and skip the resistor. Figured now was a good time to do it.
http://www.summitracing.com/parts/PNX-1144A Thanks Ron |
Nothing but bad luck with them. I had the one that if you had the key on and the distributor was just right it would NUKE it self. You also had to pull the distributor gear to set the thing up. There was a ring that ran thru a pick up with an air gap (clearance) that never ran straight. JUNK in my book. Have SE Breakerless in both my tempest with no problems. If they ever failed just remove distributor cap and install points and be on your way. Just My Opinion
That is the kind of info I am looking for, but what about us 4 cyl. guys? Any other options out there?
Ron Last edited by ronk455; 01-17-2011 at 08:15 AM. |
I use Dave small body HEIs and Pertronics.I have had one Pertronic failure in the last 12 years with useing at least 20 of them.I have them in 3 of my cars now.Tom
I have one of the conversion kits in my tempest and it works great. I chose to do the petronix coil as well. No more changing points!!!
Andy 1962 Tempest Lemans 4 cyl auto 1967 Camaro 1969 C/10 1969 D300 1972 K/5 1974 'Cuda 2005 2500HD Duramax |
Gary |
That's the smaller aluminum one. Do you have a picture with the petronix conversion kit?
I don't have any photos of it. I can try to take a few tomorrow.
