Optons for brighter headlights?
1969 LeMans - what is the best option for a brighter headlight. This one is going to be my "daily" driver. Thanks
Mike |
Relay kit
Some people have used relay's to give the headlamps full voltage. Here is one example of a place that sells kits. You could save money by making your own setup but, (Mad) gives you a manual with there kit................
http://www.madelectrical.com/catalog/rly-1.shtml
Frame off (resto mod) 68 GTO - 406, 0-deck, E-Head home port 87cc, TRW L2279F30, Comp. flat solid .577/.577 - 248/248@.050 110LS. 700R4, Precision Industries 3 disc 10" lockup 3500rpm, Moser 9" 4.11, Detroit Locker. |
If you have not stepped up to a halogen bulb, there is a noticable improvement there. Proper headlight aim also makes a difference in usable field of view.
I think halogens would be the best bang for the buck. I'm almost debating putting some projector beams in my car, but that is a project best suited when the car is done.
I have halogens in my 69. It was a MAJOR improvement.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Run the headlamp ground wires back to the Alternator case.
I'm running halogens and relays.
Just having new bulbs makes a big difference, light bulbs lose brightness every year of their life
My Break Away Squad 1969 Fbird (base OHC, 350, 400HO & Sprint Cvt’s - 400HO & TA ht’s) 1969 Custom S 2dr ht 1969 LeMans (2dr & 4dr ht & Cvt) 1969 LeMans Safari wagon 1969 GTO (2 Cvt, 2 ht & Judge ht) 1969 Cat (3 Cvt’s & 2dr ht) 1969 Ventura wagon 2 seat 1969 Exec 4dr post 1969 Bonnie Cvt & 2 wagons 1969 Bonnie Brougham (4dr ht & Cvt) 1969 Grand Prix 2 SJ’s 1969 2+2 2dr ht (Canadian) |
I'm using Halogen Headlamps in my '69 and it does make a big difference over
the original ones. Good headlight aiming is a must as well.
- '69 GTO RAIII 4 speed H/T - '09 G8 V6 |
