#61
i have a Dyno appt. on the 18th. after reading this i bought a 1" super sucker. it wil be interesting to see what it does.
11.940@114.21 / 1.843 60'/ 3980 lbs 1964 corvette roadster 1968 corvette roadster 1962 corvette "equal rights, not equal things" if you want to know the future, read "atlas shrugged" I dont race a 4spd because it is easy, I race a 4spd because it is hard. ![]() |
#62
Craig. I used on of your cams in a 455 build in '76. Whatever the RAIV copy was. Ran fantastic. Several years ago I found an unused set of your tri-Y headers in a swap meet and grabbed them ($75) knowing they would get used somewhere/sometime in the future. I ended up using them on my '73 Trans Am Turbo build by shortening the 2 inch secondaries Blah blah bah. But they worked fantastic for me. I wished I had them back but I sold the car with them. I still have all your books/catalogs, even the 350/326 additonal book. I remember pouring over those pages, and the M/P 326 was just a dream for me. Anywho, just wanted to say thank you for all you two did for us. Ok, enough grovelling. Thank you for all you did. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
#63
How do you think the Rocket box would work in a boosted situation? Other than extra plenum do you think it would make any difference? Just wondering. This would be a blow thru carb setup. Mark L
#64
![]() Quote:
#65
Boost makes up for a lot of inlet deficiencies of course. A 'Rocket Box" spacer should help. See post #64 for a possible 1in example.
#66
Caig, after I posted I realized that you are talking about this to help with a spreadbore based carb. Neither the Q-Jet or a Holley spreadbore is a good candidate for blow thru so it probably would not even be a situation. But in a N/A--nitrous situation and a spreadbore I can see it really working. I've always been a big proponent for large plenums in a race situation so I can see the "BOX" as beeing a big help in that alone. Mark l
#67
A Q-Jet isn't a good candidate for a Spread bore ??
GOOD IDEAS ARE OFTEN FOUND ABANDONED IN THE DUST OF PROCRASTINATION |
#68
If you want to explore this even further just ask Butler about effects of intake flows on natural aspirated motors with intake turtle's
http://www.jbp-pontiac.com/products/...s/turtles.html |
#69
OOps I meant blow thru-not "spread bore"
#70
I think that IF you know what you are doing you can make a Q-Jet work just fine under boost in a Blow-Thru application. Ken C would be the guy to talk to about doing it right, IMO.
Tom Vaught
#71
Who'd want to do something crazy like blow-thru a QJet??? Never mind, I don't want to encourage more thread drift than there already is. :-)
Ken was only one of a handful of guys who knew the design and interior shape of the "Rocket Box" from inception until recently. There were also more "secrets" in the H-O 455SD SS/KA national record holder than have been generally disclosed. Ken was responsible for one and contributed to others. He was General Manager of H-O Racing during that time for good reasons. Thanks, Ken! Last edited by Craig Hendrickson; 04-17-2011 at 07:05 PM. |
#72
![]() Quote:
I never tried a "turtle", but I can appreciate how it would have merit since air/fuel does not like to make hard angle turns. |
#73
![]() Quote:
http://www.carcraft.com/techarticles...ild/index.html |
#74
Just don't confuse Ken Crocie with Ken C of KRE racing.
#75
With the huge popularity and growing interest in "old speed parts"; have you ever thought about maybe having someone make reproductions of the "Rocket Box"? I know it wouldnt be practical for street use, but i think a lot of racers could definately get a ton of use out of it. I dont have a race car, but I would still buy one, if for nothing else to have a copy of an awesome piece of Pontiac history. I am sure just about everyone that has posted under this topic would probably buy one. I think it would be awesome to finally see something new (can i still call it new?
#76
i know you spec'd this out to work with the torquer I intake, would it work as well on a warrior/ doug nash intake?
i have a D-port 455 i am thinking about running in a 74 S/S body and was thinking of using a warrior intake. i do have a untouched torquer I, and a victor sitting around just incase.
FREEDOM ISN'T FREE BUT WORTH FIGHTING FOR |
#77
![]() Quote:
Please post pictures of the mount flange of each and the dimensions of the Dominator bolt hole center-to-center and current plenum opening. Within 1/16in is good enough for now. Also, how thick could the spacer be, i.e., how much vertical height is available between the mount flange and bottom of the carb base? |
#78
Hi Craig, thanks for divulging this info, much appreciated
How do you think the 80% bell applies to other media ie Water as opposed to compressible gases under pressure (rocket) or Vac (intake manifold) Slight hijack here but related I am sure We uitilise a "straight" tapered exit nozzle in different diameters in our jet unit. I have been searching for years on examples of different COD for nozzles using water to generate / maximise thrust but to no avail. A typical nozzle would be 115mm dia and we would see 170 psi throught it at WOT (6400 RPM) Heres a quick link to what what it does (my boat, Pontiac Powered of course !!!) http://www.youtube.com/watch?v=3ffCw0rR8pI
Working on going faster (and now staying dry at the same time !!) |
#79
![]() Quote:
We are building a 474 with a set of CV-1 heads and discussing the air-flow of an early CV-1 intake manifold and it's effects (anticipated) and the turtle was something he felt could really assist in directing/balancing air flows within the runners.. As stated N/A air doesn't like hard angles/ bouncing on the floor and the internals on the intake design just had us thinking out loud..... Wilson also does the intake spacers that effect air flows (not sure about Q-jet app's though) Butler sells the turtle product,,, so I'm sure he as a master builder could shed better light on this if you called him..... |
#80
Sorry I should have specified a Q-Jet is not a good candidate for a really high HP blow thru. Only because of the small fuel well/bowl and inlet area. I (just me) do not believe it can flow enough fuel thru the single inlet. No doubt that it can work on a moderate (700-900) hp setup. Sorry for the confusion. My opinion only. Mark L
