E-85
can someone post the link to the e-85 carb conversion guy. thanks.
69 GTO 11:66@114.17 all balls no bottle 406 d-port iron heads 3700lbs all steel |
Carburetor building & modification services Servicing the Pontiac community over 25 years |
This is the guy I used. He is in central IL. The carb he built for me works very good. I've used it on a 406 sbc, and used it on my 406 Pontiac last year with only a small main jet change. http://kenjonesperformance.net/
Mark took my power valve out. Always ran one with success so was a little disapointed when it wasnt there. Maybe i should've specified that i wanted it there. |
heath_daniel@hotmail.com Tell him what you have and what you want to do it's that easy!!! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
Horsepower innovations if you want a new carb that is set-up specifically for your car...
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Simply put you increase the carbs fuel flow by about 30% and there are some items you replace to handle the E-85. I recomend anyone going to or using this fuel to run your own wideband in your car to varify the proper A/F ratio.
What is a usual or ball park cost to convert? Say a Holley 4779 750. Just curious for a cost. Thanks. MArk L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build. |
Patrick from Prosystems did mine. New carb and pressure regulater was @$900 to my door. took the new carb out of the box drained the last remaining gas from tank. poured in the moonshine was running in @1 1/2 hours. carb was perfect right out of the box.
Pro Systems charged me about $400 each when I had my old 850's converted a few years back. I've been running their SV's the past couple years now.
The secret to happiness is not getting what you want but rather, wanting what you have. |
Mark Sullens did my 1195 King Demon. No problems
Todd Sedlmeier Who ever thought pinewood derby cars would lead to this! October 2004 HPP Shootout participate http://www.highperformancepontiac.co...out/index.html 86 Grand Prix 535 High Port 8.93 @ 153 65 GTO 433 High Port 12.04 @ 113 |
