oops
chuck... 1973 455 TA (07A) |
I've got that same shot. Almost Notice my Negative battery terminal stud has been "put out to pasture"
Auto Zone Temp Sender
The autozone sender is made by Wells; it is part # TU5.
Another one I have had good luck with is sold by CarQuest. It is part # 53-7719. In my tests both of the above senders were very, very close to the old AC Delco # 1513321. In a case where you have a laser gun and your gauge still reads 7 to 10 degrees hotter on the dial than actual, (and you have tried one or the other of the 2 above senders) try a Sorensen TSU5. WARNING: STAY AWAY from both GM #12334869 AND NAPA # TS6469SB. Both of these have low resistance and will cause your dash display to read anywhere from 10 to 20 degrees higher indicated temps than actual. (Verify with a laser gun.) Quote:
Peter Serio Owner, Precision Pontiac Last edited by Peter Serio; 07-03-2011 at 02:32 PM. Reason: added one line |
On ebay, a seller's car fitmet chart says the Wells TU5 won't work on 70s Firebirds with guages. Sure looks like the right part, though.
Here is my original testing in the old thread. You can see the Wells TU5 was the closest specs to the original, old sending unit. http://forums.maxperformanceinc.com/...=632070&page=2 |
Real Temp Sending Units
I have 3 original ones that look as good as you will find. All have the AC Delco upside down.. ANyone want one just PM me, beats the heck out of a repo one..
Played with a TU-5 last week with a stock 70 gauge set. Mine was close, but not perfect, so being old and anal, I tried for more LOL. I wanted to see what "actually" happened to accuracy with a added resistor in line. So I calculated what I needed and had a friend put it way back at firewall. I noticed it nailed the operating temp, which was 180 water with a 160 T-stat,( and im sure well over 200 in the cylinders for those with efficiency in mind).
SO we changed out a few and it changed the gauge reading. I then hooked it to the TU 5 in hot water ( pan of water with jumper wires) to the gauges in the car. ran the water to 200, and got 200 on the gauge, 210 seemed right on..tried 150, was very close...Now I wondered why all the hype on other forums about it being not accurate. The temp gauge itself has a resistor to make it compatible with the senders used at the time. So I figure why would an additional one make it not accurate at any other temps> and why would they say its accurate for the TEMP you make it but not others? This info is FALSE. That said..The difference was this, the reaction speed was slowed a bit, across the board. going up and down. Technically mine should have been as close as Steve's, BUT old "wound" resistors on back of a gauge can loose their insulation and some of their resisting properties making gauges read higher. The right way may have been to bench test the whole thing and make the total "back of gauge" resistance match with the sender resistance for accuracy. May have to do that someday.. so Im running a 20 ohm resistor... hehe
on my engine i dont see a temp sending unit on the engine head as your pic shows, the only one a have is on the intake its a 3 prong...
'72-later were in the cylinder head, '71-earlier mounted in the intake.
"XE cam basher" |
OEM Temp Guage sending unit
Guys..I have one more original used Temp Sending unit I will sell.On the other thread,3 prong sender, I posted that I had some of these. Really beats adding resistors,cuting into the harness etc.. Just seemed to me a bit much when GM used this sending unit on many Pontiacs in the early 70's-they are not that difficult to find..
Anyway, I sold a number to others and will sell one more.. $25 plus shipping $7. I think I am being quite fair with this price.. Just shoot me a PM and I'll respond within a day or two. Pls do not PM me if you already have one and just want an extra one for $25....Let's let this go to a board member who doesn't have one and needs the correct unit.. This is a really nice unit.. Hare to tell it is almost 45 years old.. |
