Trying to remove the brackets and metal pieces from a 70 GTO Endura bumper. some of the bolts/studs are spinning, can't get the nuts broke loose.
(1) Any tricks to get this figured out, to get the nuts broke loose and remove the brackets and whatnot? (2) With these bolts spinning, in a "rubber" (endura) bumper, won't they just go to spinning again when I go to tighten everything back up? any fix for this? Has anyone else ever had issues with this?
Matt 70 GTO 400 4-speed "Turbos make no noise and leave the line like Baby Diarrhea!" - GTOGeorge |
Here are a couple of old threads where epoxy repair is recommended:
http://forums.maxperformanceinc.com/...ht=endura+stud http://forums.maxperformanceinc.com/...ht=endura+stud I tried a lot of repair methods on my 68, but none of them worked for me. I ended up drilling a hole into the front face of the Endura bumper, removing and replacing the spinning carriage bolt and then filling the hole with flex epoxy. Last edited by jmt455; 08-27-2012 at 09:42 AM. Reason: clarification |
X2, I found it easier to use a cut-off wheel and cut the bolt, then replace it.
1964 GTO Auto 1970 GTO Ram Air III 4-speed 1972 Lemans Convert with endura option, 455, 4-speed |
X2 here also..sorry but it's a pain!
