Old 09-30-2012, 12:19 PM
1963409 1963409 is offline
Default 1962 GP Clutch Fork Spring/Plate
I was assembling the bell housing and clutch fork on my 62 GP 4spd car, I cannot remember how the 2 metal plates and clutch spring sit on the clutch fork? Does anyone one have a picture? Do they both mount on the inside with the spring in-between? I pulled my parts book and do not see any picture of that? Help!
Old 09-30-2012, 01:08 PM
Stuart's Avatar
Stuart Stuart is offline
This is from the 1961 parts catalog, and while it's a picture of a Tempest bellhousing the clutch throwout arm cover parts are pretty similar. The flanged piece goes against the bellhousing, then the flat piece, then the spring which hooks into a hold on the arm to hold it all in place.
Name:	throwout cover.jpg
Old 09-30-2012, 02:37 PM
chiefpontiac66 chiefpontiac66 is offline
As I recall, my 62 went together the same way as Stuart's photo.
Old 10-08-2012, 06:09 PM
Stuart,
thanks for picture, I just got back to it yesterday. Is there supposed to be grease between plates? metal to metal contact on every shift? Mark
Old 10-08-2012, 07:05 PM
Stuart's Avatar
I don't know if it's required but I put some grease on mine, it seemed like a good idea. Having said that I didn't notice any previous wear on the parts from rubbing against each other.
