Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
69 firebird was 455, 4 speed, (budget) now LS-Lm7 5.3 gm swap
So I indecided to stuff a 2000 up, 5.3-lm7 or ls series engine in my 69 firebird, sold the 455 and the 4 speed muncie. This is the list of parts that i need to buy
TH400 JW ULTRABELL 92451LS ENERGY SUSP. SBC M-MOUNTS CORVETTE LS6 OR ZRI CAMSHAFT 98-2000 CAMARO CORVETTE INTAKE FUEL RAILS 50-60 LB INJECTORS PAC VALVE SPRINGS 98-00 CAMARO WATER PUMP P/S PUMP AND RESERVOIR HEADERS---DOUG'S 1350--DRIVESHAFT 80MM T/B 99 CORVETTE FUEL FILTER STAND ALONE ENGINE HARNESS REPROGRAM ECU UNDECIDED IF TURBO IT OR NOT??? SINCE THIS MOTORS MAKE DESCENT H-P AND ARE CHEAP TO BUY...--TIME AND $$$ |
car updates
So i decided not to buy the jw ultrabell, instead i had my local trans built me a th400, i also bought the converter, 3200 stall, GM spacer, bolts for the spacer and cadillac cts-v oil pan, dipstick and tube, here are some pics
GM spacer #12563532 GM (6) bolts #19257940 |
Looking good brother. Check out the Ls1tech classifieds often for deals. Here is my twin-turbo LQ4 setup.
I have a 5.3 in my '68 LeMans and am going single turbo because the C5 FEAD blocks my older twin-turbo manifolds. I went with an '04 LS6 cam (5308), LS9 timing chain, LS6 intake and LS2 springs. If you go with the ZR1 cam you will need more parts since the CPS is located on the front of the newer Gen 4 motors. Your Gen 3 ls, like mine has the CPS in the back. Not worth the hassle in my opinion. |
ls 5.3 into older pontiacs
updates 69 firebird 5.3 gen III
here are few more pics, got my ebay headers install, th400 trans and 3000 stall behind it. motor mounts were a pita...lol, the oil pan i used its from a cadillac cst-v, it berely clears the drag link...motor mounts sit my motor way back...
Thanks, I was not aware of that spacer. For those swappers who don't yet have a converter I found out CircleD makes a custom t350/400 converter with CNC billet front cover that bolts direct to OE LS flex-plate. https://www.circledspecialties.com/p...converter.aspx |
Sorry for the late response bro. My manifolds are Mustang T3 manifolds mated to LS flanges.
manifolds tourbo??
how were you able to do that, the tubes matched the mustang 302,351w. head exhaust layout? thats interesting, can you elaborate on that please? i know they sell plenty of 302 turbo exhaust headers on ebay too.
69 firebird ls motor
here are some more pictures of my car, i am almost done,cant wait to drive it...
You do good work brother.
I am considering a LS installation into a 69 Firebird as well. Do I need a different oil pan other than the factory 2004 GTO LS 1 pan, will it not fit well ? Thank You.
Tim john--- |
ls1-5.3 swap 67-69 firebird
Tim, that oil pan wont work, Holley makes a nice one, ebay sells them for $399..buy the headers and the motor mount kit from "DOUG'S HEADERS", also you need the stand alone engine harnes for you engine...cooling fans from a 98-02 camaro-trans am ls1, if you are going toinstall a complete LS1--motor,stock, you need to have the ECM-reprogram and also remove the ANTI-THEFT-VEHICLE....Its tricky and kind of pricey, try to buy your engine complete, pulleys, p/s, alt. intake that will save you some good money..good luck man..post pict. about your project
Engine that I am considering will be a complete take out of a modern GTO. I also would like to know about using a Tremec TKO 600 five speed, will the Tremec work with the factory GTO LS-1 flywheel and hydraulic clutch ? or do I need to go with what HURST Driveline offers in kit form.
Tim |
69 firebird ls
Finally installed the exhaust by PYPES STAINLESS, o2 sensors, stand alone harness, air intake, bosch fuel pump, 36lbs injectors, my centerline rev wheels, 15x4 fronts with 205-70-15 and 15x10 rears with 275 drag radials, I was able to start the engine, idles fine but will need tunning cause of the cam and injectors change, next fill tranny up with fluid and maybe test drive it...here are some pictures, sorry kind of small, they were taken with my cheap ass cell phone...
Great looking piece brother. Great!!! So where are you going to mount the turbo...lol
TTT..SO after many months of braking my head , I was going to take my car to a dyno shop have them dyno...long story short dyno shop "WESTECH PERFORMANCE" SOCAL. they told me I had to leave the car for a whole day plus $1000...I said o chit not now...so I went the easy route--- carb..i finshed all the carb set up and I being able to drive the car around the hood all i can say, oli chit it pulls hard...didnt think that little motor was going have much power...after all the money spend It would being better to keep my 455 and upgrade it...i probably stick another 455, E-headed, roller cam motor back in there...here are some pics of my carb set up...
Those little motors really come to life with either a good cam or boost.
very interesting journey here.
I had a question that skimming didn't answer. What front springs did you use for the swap? |
