Old 02-06-2013, 11:54 AM
archerytony's Avatar
archerytony archerytony is offline
Default strongest manual tranny
Anybody out there tried diff manual trannies? Which one do you think is the strongest for street and strip? for 500 to 600 hp
www.bowhanger.com
468 poncho powered 66 cutlass
77 Trans http://s1059.beta.photobucket.com/us...rnout.mp4.html
Old 02-06-2013, 12:42 PM
FrankieT/A's Avatar
Used my Muncie behind a 454 chebby, with NO2 and slicks, no issues. Now that trans is in my trans am 455, no issues except no overdrive LOL
Old 02-06-2013, 01:08 PM
Tim john Tim john is offline
Tremec TKO 600 is my reccomendation. And for serious abuse the same unit with "Liberty Gears" (Detroit, Michigan) treatment and enhancements.
Tim john---
Old 02-06-2013, 03:35 PM
stevep's Avatar
stevep stevep is offline
The strongest manual that I know of is the Dearborn 3 speed.
GM had a test for stick shift cars called the Bonzai Test and the Dearborn was the only one that survived.
Old 02-06-2013, 04:03 PM
pastry_chef's Avatar
Originally Posted by Tim john View Post
Tremec TKO 600 is my recommendation.
X2
I know a guy who abuses his cars like crazy - his TKO600 held up for years behind 700 HP on engine and even put nitrous through it as well.
Old 02-06-2013, 08:30 PM
Formula8's Avatar
Formula8 Formula8 is offline
Tim john---
X 3. But I might be biased.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi.
Old 02-06-2013, 10:58 PM
4dblnkldude's Avatar
I went through two m-21's, and one super t-10 before getting a tko 600.
Old 02-07-2013, 01:46 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Absolute strongest? Tranzilla from Rockland Gear is rated 1,000 ft.lb. and 1,200 HP.
Old 02-07-2013, 01:52 AM
blueghoast's Avatar
I've been useing my top loader for over 20 years.
GT.
Old 02-07-2013, 10:25 AM
GT.
Ever hear of Auto gear out of NY? had a guy tell me about them and I called and talked to them looks like they build a muncie clone called a m 23 along with some others that are supposed to be very strong. Any feed back from anyone
www.bowhanger.com
Old 02-07-2013, 11:32 AM
I'm looking closely at that transmission as well. Basically a beefed-up M22. They make them with 3 different gear ratios, 2.20, 2.56, or 2.95 1st gear iirc.
Sold new at Ace Wilson's Royal Pontiac
http://www.youtube.com/watch?v=cUHC-Z8xhtg
Old 02-07-2013, 12:41 PM
I have one - essentially they use beefed up parts; ie iron midplate, Supercase, etc. I did not want to deal with Keisler and his empty promises anymore and did not want to butch up my Lemans floor pan. I am leaning TKO 600 for the T/A, mainly for the 0.82 overdrive as I feel .67 is a bit much...
Old 02-07-2013, 12:46 PM
Jericos on the race side. Although one of my Mopar NSS firends has a Liberty box in something like a Muncie case.
Old 02-07-2013, 02:41 PM
David Jones's Avatar
My TKO has about 1500 miles on it now.
Guess I need to go out and drop the clutch......
Old 02-07-2013, 03:08 PM
BB70's Avatar
BB70 BB70 is offline
i also bought a Auto Gear M-22, didn't get the M-23 option , but did get everything else. First gear is 2:20, looking for a deal on a Gear Vendors unit and finish the car and have some fun. John
Old 02-07-2013, 03:15 PM
GTO Dan's Avatar
GTO Dan GTO Dan is offline
Yup. I run one. 474 600 hp/tq in a 3600 pound 72 GTO with a ram rod vertigate style shifter. Direct bolt in for a Muncie. Runs like an M-22 on the street. I drag race it and Autogear frowned upon powershifting it at that weight and engine torque. But I have not had problems.
When considering what is strongest you must consider how you are going to use it. If you don't use tires that hook then most any suggestion here will work. If you are going to run it hard then you will likely need give somewhere...in the clutch or at the tire or some of both if not something will go boom.
The TKO do offer the O/D and if you street drive it and have a highway streetable engine they seem like a good choice.
I am going to a G-Force with the 535 I am putting in.
Old 02-07-2013, 04:16 PM
GTO Dan's Avatar
And to get right to the point...the strongest (in no particular order) are Liberty, G Force and Lenco. They are pricey but will handle 1,000+ HP at some obscene weights.
Old 02-07-2013, 08:06 PM
Formula8's Avatar
Quit being a wuss. I was beating on mine after about 250 miles! I have about 1500 on it now as well and since it is currently on the floor in the garage, I suppose I should change that stupid expensive fluid.
Old 02-07-2013, 08:09 PM
Formula8's Avatar
I have the .67 and if I had it over to do again, I would go with the .82 OD with a 3.23-3.42 gear. That being said, crusing around at 75mph @ a bit less than 2000 rpm is kinda' nice too.
Old 02-07-2013, 08:30 PM
Silver Judge's Avatar
I have one of these trannies in my Judge right now with a 2.52 to 1 first gear ratio
I like it.
501 HP, 554 ft lbs TQ
