Old 04-14-2013, 06:38 PM
blue goats's Avatar
blue goats blue goats is offline
Sorry it took so long the GTO was 4th on the car list this weekend after the lawn but here it is.
Name:	PMDon USmag1.jpg
ID:	319798   Click image for larger version
Old 04-15-2013, 08:30 AM
DevoBuzz's Avatar
DevoBuzz DevoBuzz is offline
Can you weigh those rims? Just wondering how they compare the the YearOne Ralley II's (which are heavy). Thanks.
1972 LeMans
461 stroker 10.3:1
Edelbrock D ports Scorpion 1.5 rockers
Comp Cams "Stump Puller" roller
Holley Ultra Street Avenger 770
Ram Air III exhaust manifolds
2.5" pipes Dynomax VT w/crossover
Edelbrock Performer RPM
TH350 2.78:1 10 bolt
Old 04-15-2013, 08:42 AM
63gpman's Avatar
63gpman 63gpman is offline
Thanks for the pics. Not sure that would work out. Guessing might have better luck just trying to get the lucite to work w/in the center cap that came on the rims. Might take some work to figure this one out.
Thanks again for the pics.
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 04-15-2013, 09:51 AM
JC455 JC455 is offline
Thank you for the pix.
I agree, not sure about their compatability. I still like these... could even have some custom centers engraved. Hmmmm....
John
IG: @crawdaddycustoms
Old 04-15-2013, 11:45 AM
amcmike's Avatar
amcmike amcmike is offline
I'm interested to know as well. But I already expect they will be HEAVY, since these are the one-piece cast. There is a two-piece forged version, but $ will go up exponentially.
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman
Old 04-15-2013, 08:45 PM
blue goats's Avatar
Drilling out the US Mag cap to accept the lucite section of the PMD cap would be the way to go. Then use glue or some keyway to attach the lip to the back to the cap.The US Mag logo outside circle is 1.670" and the lucite exposed is 1.8" + or -. The problem I see is that to do this work you (by this I mean me) would need to take this to a machine shop. I personally wouldn't do this on a drill press with a hole saw.
Sorry I can't weigh the wheels by themselves now the tires are on them and the wheels are on the car.
Hope this helps ,
George
Old 04-16-2013, 08:41 PM
amcmike's Avatar
This comment worthless without pics.
Old 04-17-2013, 10:01 AM
john31s john31s is offline
I have a pair of YO Rally IIs on my Lemans and they are thick cast aluminum. Because of this I needed to add extended wheel studs because the original ones did not come far enough through the wheel to get proper engagement between the stud and lug nut. If you don't want to do this others have used extended thread lug nuts.
1970 Lemans 350/ TH350 ProTouring Madness
Old 04-17-2013, 06:10 PM
blue goats's Avatar
John,
That is not the case with these wheels . I got 5 full revolutions with the supplied lug nuts.They are nothing special just short shank capped chrome lug nuts. I could have used my black cap originals but I liked the way the supplied chrome ones look better.I did have to buy a 1/2" deep thin wall socket set to install the wheels though. They are anodized and have a removable white plastic non scratch sleeve on them, $40.00 from summit. If you check out the left thumbnail pic in post 21 you can see how recessed the mounting holes are .That is the front wheel the back is not that inset but still uses regular nuts.
I'll post pics this weekend Mike. I promise.
George
Old 04-17-2013, 07:48 PM
DevoBuzz's Avatar
So does anyone have a link that contains the wheel weight of these? I couldn't find one. Or can you weigh the wheel and tire combo - the tire mfgs usually post a weight of the tire somewhere, so we can do the subtraction.
1972 LeMans
461 stroker 10.3:1
Old 04-17-2013, 08:04 PM
63gpman's Avatar
Try contacting the ebay seller to find out the weight.
http://stores.ebay.com/RONS-RIMS1?_rdc=1
Brad Hansen
Old 04-28-2013, 09:44 PM
blue goats's Avatar
Sorry it took so long for pics.
George
I'll try to weigh what I have next weekend.
ID:	321478   Click image for larger version
ID:	321479   Click image for larger version
ID:	321481   Click image for larger version
ID:	321483   Click image for larger version
