OHC-6 TECH Over Head Cam projects, questions and advice.
Old 04-14-2013, 07:07 PM
PMD1969's Avatar
PMD1969 PMD1969 is offline
Default HEI
Is there a bolt on HEI that looks OE for the OHC?
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213)
99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale
http://sohcsix.yuku.com/forums/1/OHC-lounge
Wanted: 1969 OHC "H" Camshaft
Old 04-14-2013, 10:48 PM
Too bad that there isn't a company like this for our OHC 6's. This company is what Primatech was supposed to be before they imploded.
I don't believe that this can be adapted to our engine, but maybe someone would know more than I.
http://stoveboltengineco.com/catalog...515&id=1222040
Old 04-14-2013, 11:45 PM
GTOWAGON's Avatar
GTOWAGON GTOWAGON is offline
Put a pertronics in it works better looks better and cheaper
When you really do something right it's like you didn't do anything at all
1931 Pontiac 5 window coupe OHC6 powered
2015 GMC Yukon SLT
Old 04-15-2013, 09:32 AM
PMD1969's Avatar
I did put one on but it is the lower cheapy one. Someone said that the 2 or 3 would gie me a bunch of troubles.
Old 04-15-2013, 09:46 AM
GTOWAGON's Avatar
I have 20 years or so on an original pertronics unit with never a problem however I have had a lot of failures with hei 's over the years plus the hei it the ugliest thing ever
2015 GMC Yukon SLT
Old 04-15-2013, 11:34 AM
PMD1969's Avatar
Pertronix does offer a hotter coil and wires to carry the charge. If I installed those and some better plugs would I get a better spark and performance?
Old 04-15-2013, 01:01 PM
GTOWAGON's Avatar
Give pertronics a call they are great to deal with they are verry customer service oriented
2015 GMC Yukon SLT
Old 04-15-2013, 09:50 PM
Cammer-6 Cammer-6 is offline
I have several options
pertronics
Mallory Dual life
Mallory unilite
Mallory electronic
66 TI
67 CDI
Tom Langdon also made an HEI by using a small cap one and grafting it to a OHC-6 base.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 04-16-2013, 05:58 AM
I have a couple of Tom Langdon HEI's on my cars, both done efore there was a Pentronix option. The ones I have are the large cap style. And work very well. I am sure he would make one with the small style HEI, but it would be costly. And he would need a Core to convert.
Old 04-16-2013, 09:54 AM
PMD1969's Avatar
I do have a couple 1bbl cores BUT after quickly learning that all of this would be a major change away from stock and the dollars involved I have scrapped it.
Maybe someday with the spare motor I have I can look into it.
Old 04-17-2013, 07:11 AM
Just something to think about, I understand the Time and $$$ thing myself, but Tom Langdon is in his 70's now, still in good health, but I do not know if he will be around in a couple of years or if he ould still be able to do the work. Just something to think about. He has a ton of knowlage about these engines as he drag raced them for over 10 years.
Old 04-17-2013, 10:24 AM
TheSilverBuick's Avatar
TheSilverBuick TheSilverBuick is offline
Distributorless
(I have a Pertronix II in my '67 T-bird and have no issues with it)
__________________________________________
"How I learned to stop worrying and love the OHC Pontiac L6"
The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!)
1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!)
Old 04-17-2013, 09:35 PM
Originally Posted by TheSilverBuick View Post
Distributorless
If you wanted, you could have done Waste-spark for half the coil count.
Old 04-17-2013, 09:41 PM
And HALF the cool factor. For what it's worth I got those coils and brackets on the engine in the picture for around $15 total at a junkyard. I have 4 spares as well if for some reason one or two or so don't work (unlikely).
Old 04-18-2013, 07:01 PM
looks like youre also using my trick of the oil pressure regulator for the cam galley
Old 04-19-2013, 03:12 PM
Best idea I've seen to run ~60psi of main pressure and still control lash adjuster pressure accurately. Honestly, if it wasn't for the ability to isolate it like that I probably wouldn't be building the engine, as when I go turbo I'd be real nervous capping the oil pressure in the 30's.
Old 04-19-2013, 06:12 PM
you could go to fixed lash adjustment like Tom did
Old 04-19-2013, 06:50 PM
I'm not engineer'er enough for that. I only have rudimentary fabricating skills at best.
Old 01-22-2015, 06:45 PM
PMD1969's Avatar
Jeff, can you post some pictures of what you have or email them to me?
Thanks!
Old 01-27-2015, 11:13 AM
Missed this post, sorry, I will post up the 2 different style HEI's I have, the one in my 69 Bird is the large diameter short hieght style,and the one on the engine from the Hole Shot 6 is the tall version.
