69 GTO parts
I have a long list of 69 GTO parts available. I accept PayPal and I will ship to anywhere in the US or Canada. Please be patient as I don't get online everyday. I will try and get pictures posted if I can. I do have some larger items available at the bottom of the list but these will be local pick up only please. I am located about 2 hours from the Detroit or Buffalo border crossing. You can also email me direct at dwid1@yahoo.com or give me a call 519-461-9332 (before 10pm EST)
Fixed headlight mounting plates, buckets, trim rings and brackets - $100 pair inner grills with trim (one side pitted) - $75 Headlight bezels - $85 Front bumper brackets (all 4) - $135 15/16" front sway bar (blasted and primed) - $40 Turn signals (complete with housings, bezels, lenses, fillers and brackets) - $125/pair Passenger side front lower control arm - $35 Upper control arms $35 each or $50 pair (2 pairs available) Rear lower control arms (modified boxed) - $60/pair Rear upper control arms (modified boxed) - $40/pair Rear coil springs - $50/pair Saginaw power steering gear - $65 Pitman arm - $30 th400 speedo cable - $25 Transmission back lock brackets and guard - $20 69 GTO red dash (nice core, has tear in the top) $75 Heater box with heater core, outer cover, resistor and harness - $125 Heater controls (non ac car) with bezel - $50 Gauge pod cluster housing - $75 Gauges (with bezel and printed circuit) - $200 Kick panels (will require painting) - $75 pair Hood hinges - $75 pair Wiper transmission assembly and hardware - $65 throttle cable and plastic firewall mounting plate - $35 Headliner bows and clips - $40 set Headliner tack strips with hardware - $50 set ash tray assembly (paint to match, rusted inside) - $25 Auto shifter assembly - $75 e brake assembly with pedal - $45 complete engine frame mounts for 400 - $50 set glove box door and latch mechanism (paint to match) - $50 Under rear seat cable protector - $25 Trunk torsion rods - $35 set (2 available) gas pedal assembly (complete) - $35 rear bumper support bumpers - $20/pr Door hinges - $75/all 4 Door latches and lock mechanisms - $65/pair Front lower valence panel (middle section rusted out but excellent for repairs) - $25 Front lighting harness - $50 Intermediate lighting harness - $50 Dome lamp with harness - $25 Dash harness with fuse box (everything there except plugs for steering column) - $125 Lower windshield stainless - $75 front windshield stainless - $50 fender stainless mouldings - $15 Rear window corner mouldings - $20/pair Seat belts (several colours and locations no sets) - email with needs Rear view mirror with all mounting hardware (red cover) - $25 Stainless window tracks - $50 pair front armrests with pads (paint to match) - $50 Rear arm rests (green) with pads and ribbed ashtrays - $50 Sun visors and brackets (need to be recovered) - $30/pair brake pedal and pedal pivot bracket - $35 rear bumper brackets (set of 3, rusted and need to be straightened) - $30 original rad support center bracket - $20 front drip rails - $20/set Tail light housings (plastic) - $50/pair (have 2 to choose from) rear marker lights - $25/set (will need new bezels) headlight switch - $20 wiper switch - $20 Trunk latch assembly - $20 Gas tank straps - $25 pair front ductwork - $25 dash ductwork - $20 Front disc brake set up - $275 (spindles,rotors,calipers,brackets.shields etc) disc brake proportioning valve - $50 Front steering set up (tie rods, centerlink, idler arm) - $75 Center links - $30 each Transmission tunnel metal (nice shape) - $40 red door panels (need to be redone) - $150 (complete) red window laces - $75 for all 4 15" trim rings - $50/set Rad support top plate, centre brace and brackets for 70 lemans $20 Steering column and pedal pivot bracket $25 mid 70's Pontiac dog dish hubcaps - $60/set Listed below are larger items that I prefer not to ship: rear glass (2 or 3 to choose from non tinted) - $100 each front windshield (2 to choose from) - $125 each Rear seat upper and lower (red, nice core) - $50 Full firewall and tunnel metal - $100 rear package tray with trunk lid hinges etc. - $85 Trunk divider panel with rear crossmember (where trunk divider meets trunk pan) - $85 Inner rear quarter structures with sail panel - $75 a side Roof with sub frame - $100 Hardtop frame (needs work) - $350 Complete bucket seats (red) - $500 69 trunk lid (requires work) - $150 Inner fenders - $125/pair Door glass - $65 each Rear quarter glass - $65 each Doors - $100/each (have a few to choose from) Rear bumper (needs straightening and re chrome)- $65 Front fenders (need heel patches) - $125 each Fiberglass rear quarters - $75 each Last edited by dwid; 07-24-2013 at 10:03 PM. Reason: forgot some info |
I can use the fixed headlight parts listed. PM sent
Plus I can use some other parts |
Hi
Are the 69 turn signals complete ?
with the rear retainer/bracket and the fiberglass surrounds ? pics to Scott68gto@comcast.net thanks Scott |
turn signals
Hey Scott,
signals are complete with lenses, bezels, housings, fillers and mounting brackets. Pics on the way. I will give you a call tonight. Thanks, Dan |
John
I will send you an email about the fixed headlight stuff or give me a call 519-461-9332 Thanks, Dan |
Is the dash harness for idiot lights or gauges and was it an a/c car?
harness
The dash harness was for idiot lights and a non AC car.
items sold
door glass, 15" trim rings, dash ductwork and vents - SOLD
Thanks Jeff |
Hood Hinges and front signal fillers are SOLD
Thanks Errol |
arm rests and rear lower control arms are SOLD.
Thanks Mike |
Can I see some pics of the red dash core? How much would you estimate shipping to be to 48166 S.E. Michigan?
dash pics
here are some pics of the dash.
I will get you a shipping quote tomorrow, just have to measure and get an approx. weight. |
Dwid-
Could you post a few pics of your tail light housings? Thanks!
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
tail light housings
here are the pics, they are a bit dusty
dash harness SOLD
Thanks Mike T dash core, rear springs, heater box are SOLD pending payment |
items sold
Dash Core, heater box core and harness, wiper transmission and rear springs are SOLD.
Thanks John |
Looking for nice front ds drip rail stainless steel
Thanks, George |
drip rail stainless
Hey George
I do have extra drip rail moulding but the one your looking for has some dings on it and would need to be cleaned up. |
I just need the A pillar piece . How is that part ? Or do you want to sell the whole set ( A, coupling and over side windows.)
drip rail stainless
Hey Blue goats,
I have attached a pic of the driver side drip rail moulding. It has 4-5 small dings in it (you can see a couple in the picture). If your interested $15 plus shipping. |
