Old 12-04-2013, 01:46 PM
pontiac 455ho's Avatar
pontiac 455ho pontiac 455ho is offline
Send a message via Yahoo to pontiac 455ho
Default compcams 252h
Does this cam look good for 60over pontiac 301 and with the 106 centerline can i install it straight up
Keyword Part # Grind # Search
Camshafts Shop By Engine Components Merchandise
Tech Support Forum Cam Recommendation Contact Us Warranty Registration
Social Media CPG Nation Community Events Schedule Join Our Mailing List
Charts, Graphs, & Specs Technical FAQ Technical Info Articles Instructions Camshaft Sounds Videos CamQuest™ Online
Catalogs Online What's New About COMP Cams® Logo & Image Archive Contingency Program Sales Rep Sign-In Policies Site Map
PERFORMANCE PARTNERS
Select Language
Powered by Translate
Videos Contact Us
Description Return to Store Item
Part Number: 51-229-3 Grind Number: 252H
Lifter Type: Hydraulic Lifter
Engine Family: Pontiac 265-455 c.i. 8 cyl. 1955-1981
Description: Hydraulic-Smooth idle with fuel economy for 326 to 400. Strong torque. Best cam for 301.
Cam Family: High Energy™ Hydraulic Flat Tappet Camshafts
Specifications Intake Exhaust
RPM Range: 800 to 4800 Valve Lash: Hyd. Hyd.
Valve Timing: 0.018 Duration: 252 252
Lobe Separation: 110° Duration @ .050" Lift: 206 206
Intake Centerline: 106° Valve Lift: 0.425 0.425
Lobe Lift: 0.283 0.283 Valve Timing @ 0.018 Lift:
Recommended Components
Installation Notes (These notesapply to theabove recommended components with the trailing installation note numbers)
Contact usvia email
Return to StoreItem
Exhaust
Closes 12
ATDC
Opens 60
BBDC
Intake
20 Opens
BTDC
52 Closes
ABDC
Component
Old 12-06-2013, 07:48 AM
I do not know what the stock cam spec`s are, but for a mainly street 301 non turbo motor, that 252 cam is going to want to be above 2500 rpm to get into the bottom of its peak torque band. If you had 320 plus cid that would be a better fit.
What gears are in the back of the car?
Old 12-06-2013, 08:29 AM
I went with a spec-5 (066) in mine which is a big step up from stock. you'll need to check your springs. stock cam only has .375 lift. it's tinny! anything over 200 at .050 is going to be a big change. I found the stock springs in mine were the same as some single spring SBC.
Old 12-06-2013, 08:32 AM
The lifters have a low band on them too. SBC maybe? I think normal pontiac lifters would work though.
Old 12-06-2013, 11:23 AM
The intake duration on the 1979 220hp TA 400cid motor was like 198' so if you ask me 206 duration is hot for that. Even if you had the gearing for it(like 3.90s) the motors power band with stock heads will be quite small and no fun to drive!
Old 12-07-2013, 12:55 PM
Formulas Formulas is offline
My 1978 motors manual has 2 different cams for 301, a automatic and a stick cam
Lift on them ....stick = .377 auto = .364
Only valve timing shown is Intake opens before TDC.... stick =31`... auto = 27`
Then you have to wonder how this timing is measured at .020 or .050 .005 or the slightest movement of a dial caliper
Something to consider... the modern day fast ramp lobe profile on paper is going to appear bigger than it is installed in the engine, how many times have we heard X cam stopped producing X power way early in the power band, I was expecting more from X duration at .050... Answer is in the newer lobe profiles they produce torque earlier on than one would think
If your not at the table you're on the menu
Old 12-07-2013, 05:31 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
I would run the XE250 over that cam. New springs, of course. Run the 864 lifter, not the 852 that the other Pontiacs run. Get straight studs and poly locks.
Usually not a big fan of the smaller XE cams in the larger engines but, this is where we need to build cyl. pressure with small cubes, low compress, AND poor heads.
