Old 01-12-2014, 03:19 PM
S/st 54's Avatar
S/st 54 S/st 54 is offline
Default Looking for feedback on Stefs oil pans
So I was diggin and playing yesterday and came across a few stefs aluminum oil pans and just curious if anyone has actually used one of the on there Pontiac?
One is the nostalgia pan pn 1095
The other is the super series pan pn 1240
The other is the heads up series pan pn 1730
If anyone could post some pics of the sump area also that would be great. Calvin has sent me some pics of the nostalgia pan but I'm also looking at the other 2 pans as an option.
Also anyone that could recommend a place to possibly send a pan to to have the BOP belt drive conversion done on the pan would also be greatly appreciated. Thanks guys!
"You have to evaluate the past,Focus on the future,and that tells you what you have to do in the present"--Lou Holtz
“It’s the process it takes to get to goals that sets us apart, the execution on every single play, one play,one life”
Notre Dame Head Coach Marcus Freeman
69 GTO NHRA Super Street Car
2860lbs 10.82@159.91 in Joliet May 2024 ….157.56 MPH in Gainesville in March ‘23
Old 01-12-2014, 03:24 PM
slowbird's Avatar
slowbird slowbird is offline
I ran a Stef's pan. Fit was ok, it did take a little work to fit it but not to bad. Cant remember which one I ran but it was the only one with a kickout if I remember right. It worked good until it got smashed, lol.
The Following User Says Thank You to slowbird For This Useful Post:
Old 01-12-2014, 04:23 PM
hill461 hill461 is offline
Default oil pan
St sst
I bought my pan from moroso . They did the belt drive setup when they built the pan . Also needed a little massaging to fit right but otherwise nice pan. Just make sure you tell them what block and whether or not you want to run gaskets . Ask for Jim henson
Hill 461
The Following User Says Thank You to hill461 For This Useful Post:
Old 01-12-2014, 04:31 PM
mike leech's Avatar
mike leech mike leech is offline
I run the 1240. Really like it. It's not handy or I would get you a picture of it. If I make it to the other garage soon I'll get you a pic.
EHTTFMF!
Being dead, it is not hard on you. You don't even know you're dead. It is hard on everyone else that is not dead.
BEING STUPID WORKS THE SAME WAY! The rest of us suffer.
The Following User Says Thank You to mike leech For This Useful Post:
Old 01-12-2014, 04:41 PM
They can modify whatever you want. I think they have a Nunzi's design too.
I used one on my 409 project. It took some "massaging" to fit right around the main seal area and some of the bolt holes-and they even had a 409 block there when they built it. BFH and a 2x4 to massage it. Use the wood on the aluminum.
Old 01-12-2014, 05:26 PM
slowbird's Avatar
Found a couple pics of my old Stef's pan
Name:	oil pan 1rs.jpg
ID:	349100   Click image for larger version
Name:	oil pan 2rs.jpg
Old 01-12-2014, 06:16 PM
John Langer's Avatar
John Langer John Langer is offline
Originally Posted by hill461 View Post
St sst
Hill 461
Tim in the custom shop.
The Following User Says Thank You to John Langer For This Useful Post:
Old 01-12-2014, 06:19 PM
RAIV-Z's Avatar
RAIV-Z RAIV-Z is offline
Looks similar the Stef’s oil pan I’m using on my 535. We added additional baffling in the sump area.
2023 Best ET Slip
60’ 1.224
330 3.186
1/8 4.784
MPH 152.07
1000 6.175
ET 7.347
MPH 189.92
Weight 3650
The Following User Says Thank You to RAIV-Z For This Useful Post:
Old 01-12-2014, 10:34 PM
grnmnstr's Avatar
grnmnstr grnmnstr is offline
We went with a custom Stef's pan on the new build. Looks very nice. Hopefully works just as good.
1978 Pontiac Grand LeMans.......out next year
Previous - 2001 Jerry Haas-built P/S Grand Am - former WJ car, Hoffman Racing 535" IA2, Tiger Heads/Intake, Single Dominator, PG
Best ET: 7.776 @ 175.94, 1.096 60', 2375 lbs.
The Following User Says Thank You to grnmnstr For This Useful Post:
Old 01-13-2014, 12:09 AM
cgeise's Avatar
cgeise cgeise is offline
Stef's also -- but it seems to loose oil pressure in the shut down area -- just be aware of that.
The Following User Says Thank You to cgeise For This Useful Post:
Old 01-13-2014, 01:31 AM
Ray Cox's Avatar
Ray Cox Ray Cox is offline
cartel is in the process of building a new pan that should be on the market in a few weeks I will see if I can get some pics. I have one on order now. It is a 2 piece design with o-rings. It is available for BOP belt drive or standard timing cover. You can contact them at 317-645-8786 ask for Joey B.
8.30 @ 165 mph 3,380 LBS
The Following 2 Users Say Thank You to Ray Cox For This Useful Post:
Old 01-13-2014, 01:34 AM
warriors revenge warriors revenge is offline
Send a message via Yahoo to warriors revenge
had stef's make a custom pan for me.... it was bad ass!!!! loved it!!! will buy another one... unfortunately it wasn't rod proof ;(
The Following User Says Thank You to warriors revenge For This Useful Post:
Old 01-13-2014, 01:56 AM
S/st 54's Avatar
Thanks I'm also planning on adding a oil accumulator......I've had more than a few people tell me that helps that problem tremendously...... Lol for you know the reason. .....blue rotors and all
Old 01-13-2014, 10:40 AM
john marcella john marcella is offline
This is the biggest reason I went dry sump, done with that chit.
John Marcella
Marcella Manifolds Inc.
john@marcellamanifolds.net
ph. 248-259-6696
The Following User Says Thank You to john marcella For This Useful Post:
Old 01-13-2014, 12:11 PM
Jeff Kinsler's Avatar
Jeff Kinsler Jeff Kinsler is offline
shut up you chevy queer!!!!!!
540 c.i. Ultra Street Combo
Tiger Heads with Tiger Intake
Induction Solutions fogger with .046 jet
First ultra street/ultimate street NOS car to get into the 4's!
1.079 4.559 153.23.
3100 lbs
7.77 @ 169 1/4 Mile (2015) with EHTTFMF!!
T2TTFMF!
Special Thanks to:
Ron at Rhodes Custom Auto
Butler Peformance
Jim Hostler's Transmissions (HOSGTO) on here
Induction Solutions
BES Racing Engines.
Cheeseburger
VP Racing Fuels
Calvert Racing
Old 01-13-2014, 12:57 PM
cgeise's Avatar
What you say'n Willis --------- I never use the brakes - :-) - as we speak Im putting a dry sump on the Firebird.
Old 01-13-2014, 03:23 PM
S/st 54's Avatar
LOL um me either unless I'm trying to make the 1st turn around after a win light........I'm a dialer!...................170+MPHSGCTTFMFRS!!!!!Po ntiac power at that I love it!
Old 01-14-2014, 08:17 PM
aaronman aaronman is offline
After doing some good research I bought a "Langer" Moroso custom pan for my dragster a couple years ago. No oil pressure loss while on the brakes..... And as a bracket racer I value my brake peddle as much as the go peddle at times
The Following User Says Thank You to aaronman For This Useful Post:
