switching from summit 2801 to the summit 2802 cam
i have been thinking about switching to the 2802 cam i currently run the 2801 in my stock bottom end '76 400 i have a 4 speed, #62 heads,headers, 3.23 rear gear if i switch to the 2802 will i need to do anything with my valve train i have been running the 2801 for about 5,000 miles great low end tourqe but gets cammed out quickly with a 4 speed i think i probably could use less tourqe and more top end ? What do you guys think would there be a noticsble difference in performance.
Stock bottom end?
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
stock 76 chamferd pistons,crank and no overbore
You should be able to use the same springs with either cam, provided they have the proper specs in first place for the 2801. The valve lift increase isn't enough to require any changes to the valvetrain if already properly set up using straight 7/16" studs and polylocks.
Should be a nice combo with the cam swap, definitely will see an improvement. |
when i got new cam i also got new springs sugested by summit used the stock rocker arms as well stock studs. would i need to do any thing with springs # 996 i believe
Springs should be okay.
However I would highly recommend upgrading to 7/16" straight studs and polylocks for the sake of reliability. |
no machining of the head is required
Would this upgrade be significant you think from the 2801 |
Significant performance improvement over the 2801?
I'd say about a 25 HP gain is to be had with the 2802. Useable RPM range should be extended by about 500. |
Redline? 5300-5400?
Sounds about right, good shift point for a stock 400 bottom end and that cam. Up to 5500 would be fine.
My current set up is fine just have a small detonation issue if I don't back off timing a pinch.currently it just blows up the tires and is all done quickly
If your up around 10+ to 1, i think its a good move.
Bull Nose Formula-461, 6x-4, Q-jet, HEI, TH400, 8.5 3.08, superslowjunk |
Just did this last year:
Useable RPM range moves up about 500rpm or so. Where the power comes on moves up as well. Used to come on really strong about 2200rpm and fry the tires in 1st. Will still do so but only if I make it do so. Cam comes on REALLY strong at about 2750rpm or so. This should get rid of detonation though as it bleeds off some of the dynamic compression (ask Cliff, he will explain). I shift at like 5000rpm- I think the rev limiter is set at 5200rpm on the Pertronix. Will be bumping this up this year. Stock bottom end, all rebuilt. Car has a 2.56 gear but in process of changing to 308 so will be very much like yours. |
In addition:
Car will pull at least beyond 5200rpm. If I had to guess where it starts leveling off: I would say around 5600rpm or so. 2801 seemed to be all done around 5000rpm or so. Could go beyond but not gaining much beyond that. Hope this helps Joel |
OK, seriously sucking at posting today.
670 heads on my bird, 400. |
I'm running an older Saginaw 4-speed haven't really beaten it yet but it's done good so far the car would be much faster but I shift like I'm rowing a boat. Toms go up them down
I run a Saginaw as well. 3.51 1st gear.
If you go to my Youtube channel you can see the abuse I give it. I dont speed shift it however, which I think helps it survive. Joel http://www.youtube.com/watch?v=YLQeY1gttco |
If you had your valve adjustment stock on those stock studs and nuts in may have been flattening out premature at 5000 ish, you need to do the BBC style 7/16 studs and lash out at zero with Chevy nuts or poly locks the 2801 in a decent compression 400 like yours (9.5:1 or less) should pull to 5600-5700 easily. The2802 will soften up the bottom end but can pull past 6000 making power in the 400 so it will need ot rev to show the gains but with a stock block you may want to limit shifts to 5800..
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.3 1/8th pump gas n/a 66 Star Chief Executive 57k mile 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd 2019 Chevy Spark petrol car 38 mpg |
1971 Pontiac GT-37 Car is a junk yard dog and maybe one day will be restored. |
Cool car,sounds awesome
1967 Tempest raIV 400 th-350 48k miles orig 1967 Tempest wagon 72 400 th-350 10 bolt posi(gone) Last edited by cttempest; 03-04-2014 at 12:40 PM. |
