Old 03-23-2014, 01:23 AM
400 plus's Avatar
400 plus 400 plus is offline
Default 2 circuit VS 3 circuit carbs
On the street can you tell me the difference between the 2??? AS far as street car???
461 Stroker: 265/276 Comp Cam Solid roller . 340CFM E-Head Victor Intake 1050 Dom Carb. 390/430 9" Gears with a T400 trans 4200 converter. Street weight 3850. 1.49 60ft. 275/60/15 M/T DR 10.57 SO FAR
Old 03-23-2014, 07:21 AM
shaker455's Avatar
Yes,
A 3- circuit is a direct feed from the fuel bowl to the carb & is a constant feed into the engine due to the engines vacuum draw.
With the car parked Idle can be fairly stable but underway can become unbalanced as for most part people try to compensate with the idle mix screws.
Servicing the Pontiac community over 20 years
Old 03-23-2014, 07:35 AM
steve25 steve25 is online now
The 2 circuit is best for drag use.
Old 03-23-2014, 10:46 AM
3 and 4 circuit carbs have a place in the performance community. Many times it is not on a street car or a typical drag car. I worked on a NASCAR carb one time for Ford/"others" that had 8 circuits built into the metering block. Very specialized deal to play games (during caution laps - note the venue -) and save gas.
Tom Vaught
Old 03-23-2014, 11:17 AM
shaker455's Avatar
8-circuits??...we talking cable tv here??...Haha!
Old 03-23-2014, 02:54 PM
They had emulsion holes everywhere Jeff. **
I will send you the excel file with the emulsion hole locations sometime.
Tom Vaught
** Course they had an independent "Yellow Flag" circuit for each barrel too.
Old 03-23-2014, 10:10 PM
400 plus's Avatar
Originally Posted by shaker455 View Post
Yes,
Just reading ALOT of different sides and the more I read the more Im confused LOL. My 1050 is idleing great and running strong. Just thinking im getting fuel wash on my rings. My oil looks and SMELLS funny after a short time. Need more tuning this spring. Just looking for different ideas why?? Thanks Sorry for all the questions
Old 03-23-2014, 10:27 PM
frbformula's Avatar
frbformula frbformula is offline
I run a 1050 dom 8896 3 circuit modified to a 2 circuit on my street strip car. It idels great and maintains good a/f's under all driving conditions. If your worried about running to rich and fueling down your oil you should invest In an a/f gauge.
