#1221
I sent it to Kellogg Automotive in AZ. www.kelloggautomotive.com
It takes 3-7 days, and the 488296 casting numbers they told me normally runs $112.50 plus shipping back to you. The web site says they can leave the patina, or original paint. And it when I emailed them first bout it, they told me it comes with a lifetime warranty. So I thought well worth the money to keep original part, date coded. Now I just have to pick up some paint to touch it up and install.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#1222
![]() Quote:
Karl ![]() |
The Following User Says Thank You to 72LuxuryLeMansLa. For This Useful Post: | ||
#1223
![]() Quote:
Yes, I saw where they sold tools for DIY. This pump was so rusted, and I don't have access to a bead blaster at the moment and trying to get the old cast impeller off, so I figured I would let them do it all, and like I said Lifetime warranty. Sold. If I was in your situation with a few of them to do, I would buy tools and parts.
The Following User Says Thank You to Pepi For This Useful Post: | ||
#1224
Ok after reading all of this I couldn't take it any more. I got the GTO out of storage and removed the pump and with the divider plate on the pump with the used gasket still compressed I have a gap of .125 The pump is an Edelbrock 8856. As you can see it only has 6 vanes. A lot of the pictures I've reviewed in this thread has 8 vanes. So should I just close the gap and use my pump or purchase another???
Thanks, Paul |
The Following User Says Thank You to 67droptop For This Useful Post: | ||
#1225
Paul, is it your original divider plate and is it in good shape? And is the pump still good... no leaks?
If you don't mind messing up an original divider plate, go ahead and close the gap. Tho you will might not be able to reuse it with a new waterpump afterwards. As for divider plates, there are new ones for sale on ebay. Links are in the thread a couple of pages back. Charles and I talked to Karl earlier and from what I heard the aluminum pump he bought was spot on for having a correct impeller. Costs more than a Cardone pump, but I say peace of mind is worth it. http://forums.maxperformanceinc.com/...d.php?t=749259 I'm seriously thinking of getting one for a spare. Now if you have an original style waterpump but he wrong impeller, I'd think about having it rebuilt by Kellogg Automotive with a correctly curved impeller. And that's my other choice... to have a good pump with the wrong impeller rebuilt. All of this is just my ![]()
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. Last edited by GT182; 03-26-2014 at 10:28 PM. |
The Following User Says Thank You to GT182 For This Useful Post: | ||
#1226
![]() Quote:
Pump only has 145 miles on it and the divider plate was purchased new with the new pump. What are your thoughts on the 6 vanes vs 8 vanes? Any advantages to having the 8? I'm a little concern if I will see much of an improvement with closing the gap. It seems the guys with the most overheating had a gap of .250 or more. My is .125 with the gasket. I'll close the gap and lets see what I get. Gary, without the gasket I should close the gap until the plate is all most touching the impeller....right? Thanks, Paul |
#1227
![]() Quote:
![]() ![]() Charles |
#1228
![]() Quote:
My thoughts on that question would be to say that if you have to bang the plate to meet the vanes (yours look to have been cut down), then you are reducing the pump chamber volume in effect reducing the volume of water the pump can move around. Less volume, less flow. Thats not how it was engineered to begin with. Charles |
#1229
![]() Quote:
So I should look for a pump with the taller vanes and 8 of them? The vanes on my Edelbrock start at 3/8" and curve up to 1/2" in the center. Overall the impeller measures 4 1/2 inches. |
#1230
This is what I found to put in my 67. I believe I remember those vanes being closer to 3/4" high. Shaft probably 9/16" diameter for reference. Fit the plate like they were married. Cools like it did when new.
#1231
Thanks Charles.....Looks like I'm going shopping today!
#1232
I saw this today. Has anyone used the new water pump from Ames? I'm sure PY will offer soon if they haven't yet? It looks like its $49.00.
LATE 1969-1977 GTO/LEMANS/TEMPEST CAST IRON WATER PUMP WITH CAST IMPELLER *NOW AVAILABLE AT AMES PERFORMANCE* THE HARD TO FIND NEW WATER PUMPS WITH CAST IMPELLERS AS ORIGINAL. THESE ARE ALL NEW CASTING AND PARTS. THEY ARE THE 11 BOLT WATER PUMPS CORRECT FOR 1969-1979. THESE ARE NOT CORRECT FOR EARLY 1969 WITH THE 4" HUB(SHORT). FITS ALL 69-77 PONTIAC V8 EXCEPT 301. COMES WITH 2 GASKETS. |
The Following User Says Thank You to Hooch For This Useful Post: | ||
#1233
Ok just got back from NAPA. The guy tells me the difference between the 6 vane and 8 vane is....the 8 vane is for air conditioned cars. It appeared in the catalog that the vanes on the 8 are more aggressive/taller. He ordered me one from another location and I will have it by 2pm today. He also warned me that sometimes the item ordered does not match the catalog item!!!! I guess I'll find out at 2pm! LOL
#1234
![]() Quote:
#1235
Paul, I'd get the gap as close as 1/16" if you can. Now when you look at the pump coming in, make sure it has the curved vanes that match the contour of the divider plate. If not, don't buy it. Ask them if they can get 3 or 4 you can look at. Don't worry about asking for so many as they can send them back to their supplier. I've done that here at the parts store I hang out at. Remember... the customer is always right. At least 99% of the time.
![]() As for the number of vanes. I've not seen a pump off an a/c car, but I'd say 6 is ok as Charles has with his a/c GTO and cools as it should. If anyone is using an 8 vane cast impeller I'd like to hear if it cools better..... or not.
![]() Gary Get in, ShuT Up, Hang On! Member of the Baltimore Built Brotherhood MY GTO built 4th Week of March 1966 "Crusin' Is Not A Crime" Keep yer stick on the ice. |
#1236
![]() Quote:
#1237
That's with the gasket. When you tighten the bolts up it will crush the gasket. So maybe an 1/8th of an inch will do ok. Just get it as close as you can so the impeller doesn't hit the divider plate and you'll be all set.
#1238
Got it and thanks!
#1239
Got the new pump from NAPA.....8 vanes and more aggressive but they do not go all the way to the outside of the impeller and the gap is the same as the edelbrock pump.....125 ths. With all this being said I cannot use a standard pump with my March Track Style Drive System. The front of the edelbrock pump has machine work done around some of the bolt holes. The new stock pump is thicker in some areas and this will cause a major issue with the spacers for mounting the March system. So I guess I'll close the gap on the Edelbrock pump and dividver plate and put it back on hoping for the best! Here are a couple of pictures!
#1240
Have no clue as to why the rebuilder cuts down the vane diameter...perhaps it's a vane design from some other application?
George
The Following User Says Thank You to george kujanski For This Useful Post: | ||
