Old 06-08-2014, 02:07 PM
THEGTOCHISM's Avatar
THEGTOCHISM THEGTOCHISM is offline
Default STUD QUESTION
I am running a 455 with 6x-4 heads . they have screw in studs. A adjustable rocker arm nut assembly just came off one of my valves. It looks as though only two threads were holding the nut on. My question is should I be running the 427 chevy screw in stud? And where to get the correct locking adjustment nut. thanks
70orbitorange
Old 06-08-2014, 06:04 PM
Default stud question
well it seems I need a set of 7/16 replacement studs and new lock nuts all around. I am running comp cam steel roller tip 1.50 rockets. & stock length push rods. Any suggestions on a supplier and number would be of great help.
70orbitorange
Old 06-08-2014, 07:21 PM
Nsgrn Nsgrn is offline
I bought a set new off eBay. Just do a search on there for BBC screw in studs. Affordable. They are 1/2" longer on the rocker side than the stock 3/8 screw in stud. You need them if your running polly locks. Are you using stock length performance pushrods? Either way do not use OEM pushrods with any cam and springs more than OEM specs. You will need new locks as well. There was a seller on eBay selling them for 1.00ea, they were new from kits that customers who choose stud girdle instead.
Old 06-08-2014, 07:27 PM
Here is the ones I bought. Worked perfect with the stock guide plates. And they show stud dimensions.
http://www.ebay.com/itm/Long-7-16-Ro...85fcf7&vxp=mtr
Old 06-09-2014, 01:26 PM
thanks, what brand lock nuts are you using with those studs?
70orbitorange
Old 06-09-2014, 02:02 PM
7/16x20 Contact this guy on ebay. These are the ones I purchased from him. He doesn't have any listed but he builds a lot of engines. I paid 16$ for 16.
http://www.ebay.com/usr/mittenrab
Old 06-09-2014, 02:03 PM
Pic.
Old 06-09-2014, 07:41 PM
FrankieT/A's Avatar
You should use the ARP studs, they have the tops machined. The cheaper one are for lack of a better term funky on the top and tend to come loose. JMO
Old 06-09-2014, 09:46 PM
True, ARP are top quality. Spend it if you got it. I will let you know when mine get funky and come loose
Old 06-09-2014, 09:49 PM
FrankieT/A's Avatar
You're a funny guy!
Old 06-09-2014, 09:57 PM
Formulas Formulas is offline
Any stud with a funky top can ground flat on a grinder with some care and a steady hand .. You just need a reasonably flat surface for the polylock set screw to tighten down against.
I chuck mine up in a big hand held drill then spin it while on the grind stone.. its easy.
If your not at the table you're on the menu
Old 06-10-2014, 08:31 AM
thanks everyone parts coming.
70orbitorange
