Anyone have a set of small bore head gaskets for sale? Thanks, Chad
What year specifically?
I have a pair of NOS gm ones # 9784501 for all 66 & 67 326 engines. $20 for the pair, Also have a Engine Overhaul gasket set #9774960, it's marked 1964 Tempest V/8 exc gto, it's been obviously opened, has the head gaskets inside, will have to pull everything out to see if all the pieces for the kit are there. $45 for the kit. I mite have 1965, and the early small tempest 326 gaskets, have a big pile to sort through Here is a pic of both of the above mentioned: ![]()
If you have 326HO heads then you will have problems with all regular 326 gaskets. The std gaskets overhand the chamber and have potential sealing issues. Been there done that.
Racer81x
It's a 64 2v motor. Coming out of the machine shop soon, .040 bore now from the standard 3.71875. |
Racer81x
PM sent |
