My firebird back in 1996 when purchased. 400 with 11-1 compression, turbo 400 with 4k stall converter and 4.88 gear. Maybe 450 hp. about 6mpg.
Today 462 8.7-1 compression summit 2802, turbo 400 3k stall and 3.08 gear + borg warner s475. 700+ hp. about 13 mpg. |
Tom V. Still need to do lunch at the Mac-D one day before Christmas.
My '76 Lemans Safari Wagon (400 2 bbl th350) got 8mpg.
Let me have a Diablo sandwich and a Dr. Pepper and make it fast---I'm in a goddamn hurry! - Mike 1967 GTO |
'93 Bronco w/ a 5.8 (351), E4OD, 3.55s with 30" tires got around 12mpg unloaded, got 9mpg from CO to CA towing a 65 GP.
I got about 8.6 MPG on my drive to Atco with the wagon last week. 3.90's and 3000 RPM at 60 mph will do that.
Darin '64 Bonneville Wagon (sold) 69 Lemans-All motor (sold) 9.81 @ 136.39MPH |
The 460 Truck we used for farm calls when I was in a horse practice in CA.
Second was my wife's '73 454 Chevy truck. 9mpg , 7 mpg towing the horse trailer. And it only had a 20 gal tank! You sure did not even know the horse trailer was back there and I also bet it was almost as fast as my '78 with the stock motor and 2.56 gears. Moving to CA and back to Texas there were some stretches that we were on fumes.
Really? Mine AVERAGED 15 mpg.
Once the snow starts flying and I have the blade on it the mpg's go out the window.
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
My 1970 Judge 455 .030" 744 cam TH400 3.55:1 225/70x14 got 10.5 - 12.3mpg
My 1966 Tripower 400 .030" 068 cam TH400 3.07 215/75x14 got around 16mpg. |
We rented a U-Haul 24' truck once for a move. It was brand new and we put the first miles on it. It had a Ford V-8 engine in it, pretty sure it was 370cid. Biggest TURD I ever drove, had no power whatsoever, and got between 3 and 4 mpg driving from Ohio to Virginia........Cliff
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
JohnnyB |
'69 Suburban with a 350, 4bbl, TH400 and a 3.73 rear end: 6-8 mpg.
Jeff |
I'm waiting for somebody to get on here who once piloted the mobile launch platform for NASA - 125.7 U.S. gal/mi - now that's some ****ty mileage!
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
My trash truck, 1985 F150 351W HO (it's a ho, for sure) The HO's have holley 4 bbls, I'm guessing 585 cfm. Bought it from my former employer for about half of what it would scrap out for. 8 MPG highway, w/ 3.00:1 gears. Oil consumption is close to same...
In all fairness, a fellow Pontiac enthusiast had an identical equipped 84 that got 13-15, because it was in much better mechanical condition...
78 Ford school bus that I bought and ripped all the seats out of for use as a moving truck. Also 370, 5 speed, 2 bbl. Holley. Empty or full, flat or hilly, it was gutless and a pig on gas, advancing the timing helped a little bit it was between 5-6 MPG from Memphis to Erie PA and return. Then I used it to move from Memphis to Marysville OH. Only thing good about it is I bought it in 2001 for $1000, and scrapped it in 2013 for $1350.
My 69 GTO 400, T400, roller cammed, 4.33 geared, 10.5 to 1 comp, reworked Q Jet, was about the worst car I've driven, on a good day maybe 7 MPG on the highway, 5 or less, if I was driving it hard in town. In comparison a 76 T/A, T400 with a 455, 268 HE C/C cam with 3.23 gears 9.5 comp. reworked Q Jet, about 15 on the highway, 10 in town. My K3500 dually, which I looked for a long time to find with a 6.5 Turbo diesel, 4L80E, 4.10 gear gets 16-17 unloaded combined city and highway unloaded. Towing my 33 ft, 7,000# fifth wheel camper gets 10. I absolutely did not want one with a 350 or a pig block, 454 because, 1.) It's a chevy 2.) Terrible mileage, lacking in torque compared to a diesel. My 88 IH 1600 16,000 GVW, ex U Haul 5 speed 4.56 axle with a 7.3 N/A diesel got about 12 average on the highway, unloaded 1 way, loaded return. 2005 GTO, 400 HP, 364 cu. in. 6.0L, 3.42, 4L60E, averages just over 21 MPG combined just like it came from the factory. |
68 unimog 10mpg's on 38's with 7.86 gears. With a 2.2 litre straight 6.
#39
Hands down the worst mileage of any vehicle I've owned is my current DD.
It's a '88 F350 DRW with a 460 & C-6 trans w/3.55 rear gears. Average mpg is right around 6 mpg give or take say 1 mpg or so. And yeah,as other's have said,does'nt matter if it's empty or fully loaded. All in all it's a damn nice truck,really do love it,but nodoubtaboutit the mileage is absolutely abysmal. FWIW Bret P. |
#40
