Old 01-30-2015, 10:43 AM
Firebob's Avatar
Firebob Firebob is offline
Default Performer and Holley Carb
IIRC the intake is drilled for both spread and square bore carbs, correct? Any general problems associated with bolting on a 750DP, other than the linkage and different fuel entry?
Robert
69 Firebird-462/Edel round ports/currently running the Holley Sniper/4sp/3.23posi/Deluxe Int/pwr st/vintage air/4wl disc( a work in progress-always )
http://youtu.be/eaWBd3M9MN4
Old 01-30-2015, 01:27 PM
They sell an extra plate but I never had problems with my 750 VS sealing.
Old 01-30-2015, 02:13 PM
I think they still sell the square flange plate to help seal the gasket to the spread bore intake. I always used the plate for piece of mind. I figure it helps support the holley base plate a bit more for an easier seal. I never like cranking on the nuts too much as they can distort and sometimes crack.
Old 01-30-2015, 02:50 PM
67cruiser 67cruiser is offline
Nothing wrong with a q-jet???
Old 01-30-2015, 04:01 PM
Gary H's Avatar
Gary H Gary H is offline
Default Performer/Holley
Use a 1" or more spacer if possible with that combination. The carb butterflies stick pretty far down in the intake when open and hurt the transition flow.
Old 01-30-2015, 06:43 PM
shaker455's Avatar
You should have no issues Bob.
Old 01-30-2015, 07:49 PM
I did have to massage the center divider for butterflies a little but I think that was for the Q jet. I have that on now. Ran the Holley for a few years on the 81's 400 Performer
