The 1964 positive (very short) battery cable was red.
1965 When did they stop making the long RED positive cable on the 1965 GTO. No one offers this red cable for 1965, but it definitely came on the early 65's. My 65 (11A BAL) has the OEM red standard cable (2987265UV) and two others I'm aware of below. 65 (12A BF) with Conv. Top. 65 (12E BAL) with Air Condition (2987266UV). Another interesting observation is the early 65's (no air condition) had a cad plated heater hose bracket fastened to the RH cyl. head. Most all of the 65's (plus 66-67) are painted black, which is only offered by the restoration catalogs.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
I thought '64/'65 used the Spring Ring connections? When did they switch to nut and bolt? When did they ditch the Starter Relay?
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield ------------------------------ 2015 Jaguar F-Type 340hp Convertible, Polaris White/Ebony Interior 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red/Black Interior 1965 Chrysler 300 Convertible, 383/727TF, Factory Air, Spanish Red/Red Interior/White Top |
Spring Ring battery connections were used at least through 1969. I believe they were used until side terminal batteries took over. I don't think any '65 GTO's had a red positive cable OEM.
GTO's never used an external starter relay. The '64 had the HORN relay on the inner fender driver's side. In '65 and later, the horn relay was on the firewall.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
The red + battery cable was used on the 65 GTOs for options such as power windows, power conv top, and or power antenna.
They came with a spring ring and I think 60sstuff is looking for a repro or original since the previous owner of his 65 installed the later style clamp on his original battery cable. I have the red + cable on my original 65 GTO (60sstuff if referring to my car in his original post as one of the 3 cars). My build sheet shows the "picking code" for my red battery cable application. Last edited by Option 382; 04-15-2015 at 10:27 PM. |
![]() Quote:
"America will never be destroyed from the outside. If we falter and lose our freedoms, it will be because we destroyed ourselves." Abraham Lincoln "A free people ought not only to be armed and disciplined, but they should have sufficient arms and ammunition to maintain a status of independence from any who might attempt to abuse them, which would include their own government." — George Washington |
Yes, as I said above the early 65 GTO's came with the Red positive battery cables regardless of what options the car came with.
Both my factory OEM cables had there original "spring ring" ends cut off so I had to solder new ends on them, but they still have the correct cables with "part numbers". The first two pics show the (12A) BF Conv. I mentioned above with its Red positive cable. Option 382 just showed you his Red cable. Third pic shows my neg. cable with part number. Last pic - yes it is black and white, but you can clearly see the "red cable against the inner fender and can't even see the black neg. cable".
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. Last edited by 60sstuff; 04-15-2015 at 11:26 PM. |
From my understanding the red battery cable has an extra tangent black wire that goes to a 40 amp circuit breaker on the firewall to drive the power windows, power top or power seat (I said power antenna in my previous post).
It sounds like 60sstuff is stating that the early 65s received the red + cable no matter what options were on the car. Maybe the extra tangent black wire was on certain red battery cables with the appropriate picking code during this early time frame since his picking code is different from what I showed on mine. The Fremont 65 Conv pic has the extra black wire as well as mine. 60sstuff's is the only red battery cable on a 65 I have seen without the extra black wire, of course I have only seen 3 cars with them. Last edited by Option 382; 04-16-2015 at 12:09 AM. |
When searching for a suitable repro RED + Spring Ring cable to "Recreate" the correct factory look on my '66 Lemans SPRINT 6.
I only found offerings from/For Buick, Olds & Chevy. The Corvette guys offer a few good choices.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() |
M&H will make it for you if needed .
The tangent on the Red cable (Option 382) is for power assy. #2987266UV.
My 65 (no power assy.) Red cable is #2987265UV. PS - I called M&H and who ever I spoke with said they do not make a Long Red cable for a GTO.
Ask for Daren , he can make it custom for you , if not there are other Co. that will with the part # on it as well .
