Old 06-18-2015, 10:44 PM
beertracker's Avatar
beertracker beertracker is offline
Default Help with 70 LeMans OEM Steering Wheel Install
The previous owner of my 70 LeMans installed a Grant steering wheel & installation kit. So I don't what Pontiac parts he threw away. I am installing a Pontiac OEM steering wheel period correct for my car.
I think I am missing some Pontiac parts? I have never installed a OEM steering wheel so I don't know. There is a 1" gap between the steering column and the back of the OEM steering wheel. The steering wheel has one mounting hole and the hole is larger in diameter than the steering column stud so there is too much play between the two.
Attached are some photos. What parts am I missing & what are they called. Any ideas?
I will do my best to answer your questions.
Name:	70 LeMans steering column without Grant Sleeve.JPG
ID:	400837   Click image for larger version
Name:	70 LeMans steering column and Grant 3 hole sleeve.JPG
ID:	400838   Click image for larger version
Name:	Pont OEM Steering wheel 1.JPG
ID:	400839   Click image for larger version
Name:	steering wheel gap.JPG
ID:	400840   Click image for larger version
Name:	Pont OEM steering wheel back.JPG
Old 06-18-2015, 11:01 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Default On the gap...
There will be a gap before you mount the wheel with the screw. Once it is installed, there will be a gap, but more of .5 cm. For the horn, (particularly a custom cushion), it is a spring with a black tap that goes into the horn cancelling cam. Hope that helps.
Old 06-19-2015, 10:33 AM
MescaBug's Avatar
MescaBug MescaBug is offline
Torque it down. See if it sits closer to the collar.
Old 06-20-2015, 08:11 AM
GStage1's Avatar
GStage1 GStage1 is offline
The white item on the back of the steering wheel.....appears to be the turn signal/horn contact cam...does not belong there.
George Nenadovich
Buick Performance Club Founder
www.BuickPerformanceClub.com
Old 08-29-2015, 07:48 PM
I got the steering wheel on and it fits like a glove and looks great. I had to cut the turn signal /horn contact cam back and cut the center plastic collar so the wheel fits closer to the steering post.
Thanks to all that helped.
BT
