Old 08-12-2015, 08:07 PM
AdamIsAdam's Avatar
AdamIsAdam AdamIsAdam is offline
Default How to install these parts
Ok, I give. what's the trick to installing these?
https://secure.amesperf.com/qilan/De...A&web_access=Y
Adam
1964 LeGTO
469, M21, 3.42
Sold:
1968 Pontiac LeMans Convertible
See it go HERE
Old 08-12-2015, 08:11 PM
BierManVA BierManVA is offline
Put some vaseline on them where it gets tight and whack them with a soft, deadblow hammer.
Old 08-12-2015, 08:16 PM
AdamIsAdam's Avatar
HAMMER?! I just got the car out of the body shop. I don't even want to use Vaseline, let alone a "soft" hammer! LOL
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 08-12-2015, 08:20 PM
Hey, I didn't say to hit the car!
I've lubed up a number of those types of bumpers. It works that way. Trying to push them in dry is near impossible. If the hammer scares you, just push them as hard as you can.
Old 08-12-2015, 08:24 PM
rwfisher's Avatar
rwfisher rwfisher is offline
Lube them, place in the slot the PULL them thru with a pair of pliers from the tab...
Old 08-12-2015, 09:39 PM
Chris65LeMans's Avatar
I don't think I even have those. Where do they go?
Old 08-12-2015, 09:54 PM
mgoblue mgoblue is offline
As stated, you pull them thru. Hammer? No.
Old 08-12-2015, 10:37 PM
400 4spd.'s Avatar
Liquid dish soap works well.
Old 08-13-2015, 01:02 AM
A little bit of silicone spray on them will help them go in but I would pull them through with the pliers so you don't hurt anything but never use a hammer. BIERMAN they go on the tops of the fender as they are hood bumpers. Also you may try to put them in by using a small screwdriver & push them in at the tab.
Old 08-13-2015, 01:46 AM
use dish soap, not silicone - unless you want to hear four letter words from your painter at touch up time.
Old 08-13-2015, 04:49 AM
Yeah, I was thinking of the frame rubbers I have pounded in where you can't get to the bottom side to pull them. For these you guys are correct. My advice was bad.
Old 08-13-2015, 05:06 PM
AdamIsAdam's Avatar
tnx all.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 08-13-2015, 05:18 PM
RR67GTO's Avatar
RR67GTO RR67GTO is offline
This is great, I was embarrassed I couldn't get mine in either. So I gave up and it still has the old ones. Never thought about using a pounder, or a pair of squeezers. Thank you.
Build it fast, build it right, hold On TIGHT !!!
Old 08-13-2015, 09:03 PM
GT182's Avatar
GT182 GT182 is offline
Xs 2 as 400 4sd. and Scarebird say. A lot more slippery than Vaseline, and far better than using silicone. It won't hurt anything and washes off easily.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 08-14-2015, 06:08 PM
AdamIsAdam's Avatar
Well, the fronts went in easy enough with dish soap and by grabbing them from behind the fender with a needle nose pliers. But that only works for the two front ones I can't get in behind the rear ones closer to the firewall. Boy I wish I planned ahead a little bit and bought these before they installed the fenders.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 08-14-2015, 06:16 PM
Use the end of a wood handle hammer - just push hard.
Old 08-17-2015, 10:43 AM
Willshire's Avatar
Willshire Willshire is offline
Nice looking car. Not to hijack but, where did you get the engine paint?
It's hard to soar like an eagle, when you're surrounded by turkeys!
My wife says she'd llike my car a lot more if it wasn't mine.
64 Grand Prix 389 .030, 1.65 Scorpion Rollers, Tripower, RARE Long Branch, Custom Stainless Exhaust and mufflers, 3.90 posi 200-4R. 068 cam.
Old 08-17-2015, 11:02 AM
AdamIsAdam's Avatar
Thanks. I've had good luck Dupli-Color lately. I tried that "super duper ceramic" stuff from Eastwood's on the heads and it sucked. But it is good for touching up since it's brush on. Colors aren't perfect matches though between the brands.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 08-17-2015, 11:03 AM
AdamIsAdam's Avatar
Can't do that for the rears cause the hood hinges are in the way. For now, it's not noticeable that they're not installed. I may trim them down so they snap in more easily for the backs.
Adam
1964 LeGTO
469, M21, 3.42
Sold:
See it go HERE
Old 08-17-2015, 12:46 PM
400 4spd.'s Avatar
There are 3 Harbor Freight stores on Long Island. Go to one and spend 7 bucks for #67021. This will push it in without hurting the paint.
http://www.harborfreight.com/catalog...q=molding+tool
