can i use a 301 shaker air cleaner system on a 400 pontiac?
you call yourself HARDCORE but are you truely hardcore ![]() |
no, the 301 air cleaner base doesnt have as much of a drop to the base as the 400 t/a bases. & i think the scoop is different too. also if youre using a 79 or older q-jet for the 400 the 301's base has a different carb opening style. best to try & locate a mid 70's or 78-79 t/a 400/455 air cleaner base & shaker scoop.
79 301 shaker MAY work on a 400....but 80-81 301 used a smaller diameter A/F housing...
You will need a 400 filter housing regardless..
![]() Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
There might be a height problem. Since the 301 engine is shorter than a 400, I think the 301 air cleaner and shaker setup is taller so it'll reach up through the hole in the hood. So, I think it would sit too high on a 400 and hit the hood. That's just my guess about what would happen. But, I know the air cleaner and metal adapter plate on the shaker are different between a 301 and 400.
Here's an old thread that shows pics of the different air cleaners and shakers so you'll know what to look for: http://transamcountry.com/community/...?topic=34280.0
Steve F. |
i have a dude scoop and 2 different scoop bases but the pontiac 400 air cleaners cost a boat load.
I have a spare YA-YU air cleaner in the hoard. Complete, clean, not rusty, 542 air filters, GM nOS duct hose, w72 carbs, get the check book out. Lol
Ok, what's a dude scoop????
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 Last edited by burd; 11-23-2015 at 11:56 AM. |
![]() Quote:
ok, whats a YA-YU air cleaner????
ok thanks... but what about all the other 400 engine codes for t/a's? WC, X7, PWH, etc etc. just never heard of a 73-79 400/455 t/a air cleaners refered to by engine codes. any 400/455 t/a air cleaner will work for what 79bluebird is needing.
![]() Quote:
* Your results may vary. |
![]() Quote:
![]() BUT 78-79 W72 base blowby pipe (to valve cover) is indexed at 9 o'clock instead of 7:30 ish....as the 73-76's are Also 75-79's have an extra sensor in the bottom of base..
![]() Quote:
![]() Quote:
do you mean the snorkel hole or openings? the wide oval W72 snorkel is way bigger than the round hole 180hp base opening. the 180hp round hole is 4" OD to fit the tube, but the actual opening in the snorkel is like 3" or smaller. big difference between the wide oval & round snorkels.
Lmao. I remember a big shaker like that back in the 80's. I used to see them the swaps.
🧩 Burds Parts, Finding those Hard to Find PCs, no Fisher Price Toys Here Just Say No To 8” Flakes F ire B irds 🇮🇱 |
![]() Quote:
That's why we all cut our shakers open, hell, HPP mag showed us how,lmao when you see a butchered shaker at a swap, thank HPP MAG. And their gone now, but their butchery lives on.
![]() Quote:
Even though almost every 78 T/A had them.... ![]() ![]()
![]() 68 GTO 4-spd Convertible 78 S/E Trans am L78, WS6 Auto 78 S/E Trans am W72, WS6 Auto 79 10th aniv W72 Trans am 80 Indy pace car Trans am 89 Trans am GTA |
I'm not a fan, but I've seen the snorkels removed totally. So all the air is from the shaker, a buddy with a stout 455 in an 80 T/A did this. We go to Cars and Coffee up on Woodward, lol,
"That's What SHE Said!"
