Do you still have the upper door panel stainless trim set? 4 pcs.
How are your vent windows?
1964 GTO Auto 1970 GTO Ram Air III 4-speed 1972 Lemans Convert with endura option, 455, 4-speed |
I will try to look today
1967 RAM AIR GTO 1 OF 156 AUTOMATICS |
Car I had was a post coupe,do you need just the glass or complete setup
My car is a hard top. I don't believe the frames are the same. But the glass may be. Is it softray or clear. I could use one side glass (my window frame is a bit rusted).
what about the trunk lid and rear tail panel w/tail lights and rad support.
I would like to have the 64 Door Hinges Upper and Lower both sides if available
Glass I have would be clear,which side do you need
Hey Tom I should have some hinges,,give me time to look
what condition are the frames in and how much? Wouldn't need the glass.
"The great obstacle to discovery is not ignorance...but the illusion of knowledge." Daniel J. Boorstein "Gas is STILL your cheapest thrill!" Your opinion of me is none of my business. |
How about the in-dash radio speaker support brackets? Speaker not important.
Do you have any of the trim clips from the strip at the bottom/back of the deck lid? There are six with studs and two with 8-32 screw holes. Do you have the deck lid stainless trim strip?
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Thanks, I'm soft ray, can't use the clear.
Thanks for checking.
have the trim strips for the rear panel ( 1/2 inch thick) on the bottom?
Got the parts Paul, thanks.
_________________________ _________________________________ http://www.youtube.com/watch?v=_qZgOpn-w-o <<< Burnout Video ![]() ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ "Treat Me Good, I'll Treat You Better; Treat Me Bad, I'll Treat You Worse" Sonny Barger ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ |
Again I'm asking about the rear panel trim for the Tempest. Not the one in the center that goes across about 2-3 inches thick, but the narrow 1/2 in strips that border those pieces...
No rush just looking for a spare set for the Tube Chassis car.
I would send him a P/M guys.
#38
Sorry guys been real busy,I will look as soon as I can for all parts,call me on Saturday's 631 978 8378 or text is fine
#39
![]() Quote:
#40
HOWS THE MOTOR?
DID IT RUN, AND,OR DOES IT RUN NOW. IS IT FREE, NOT LOCKED UP. HAVE ANY PICTURES, AND WHAT DOES IT COME WITH. AND HOW MUCH. PM THE PICTURES TO MY PM THANKS |
