oil pressure has dropped
I have a 389 bored to 400.It has approximately 500 miles on it. I bought the car with this motor in it so I don't know much about it. Mostly stock.
It always had 60psi oil pressure at 2500 rpm 40psi at hot idle 1000 rpm. Last week we finally got the tri power dialed in and the choke and idle set now it idles hot at 850 rpm and it has dropped to 20 psi. Going down the road the gauge is a little jumpy. 40-60 psi. Could this be a gauge problem or a pump problem? Thanks Greg |
You can get another known working gauge to test whether your gauge is the problem or not. Otherwise there may be a small piece of dirt stuck in your pump pressure release.
1967 GTO, 432 (428+.030), 4-bolt mains, factory Nodular crank, scat rods, icon dished pistons, Lunati HR 243/251@.050, .618/.622 lift, Edelbrock 72cc round port heads, 10.5:1, offy 2-4 intake, Edelbrock 650cfm carbs, Super T10 trans (2.64 first), BOP 10 bolt w/ Eaton posi and 3.36 gears |
20 lbs at idle is fine, but I have to agree that you need to get another gauge. The fact that the gauge neddle is jumping could be an indication that the gauge is going bad.
I had a similar problem a few years ago, there was a piece of Permatex about the size of a peeled thumbnail stuck in the pressure release.
Johnny US Army Retired 1978 T/A 463 Pontiac, KRE 74cc 292CFM D-ports, Lunati VooDoo, V-max lifters, TKII, ATM 850 E85 carb, TCI TH-350 race tranny, 3600 converter 3.73 12 bolt 11.63@116.68mph 1981 T/A 4-speed 406 Pontiac, Merrick ported 6X heads, Comp 270S cam, Crosswind intake 750 Street Demon, 3.42 30 spline Eaton posi street car. 1980 Formula 350 Pontiac back burner project 1972 LeMans 350 Pontiac |
Anyone ever removed the oil pan off of a 64 gto without removing the engine? Thanks Greg |
Pressure relief is in the pump.
I've never owned a '64 GTO so can't help with that question. Definitely check with a known good gauge. I was driving down the freeway one night when pressure dropped to almost zero on the gauge. I freaked out, pulled over and turned the engine off. Got it towed to a shop where they hooked up a mechanical gauge and everything was fine. The sending unit had gone bad. If you suspect the possibility of any internal damage, cut the oil filter open and look for metal in the filter media.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
You're much better off removing the engine and doing it on the stand. Check your oil pressure with a good known gauge before you jump into pan/engine removal.
I changed an oil pump like that once.......
But only ONCE..... and never, ever again!
First verify that a pressure problem exists with a known good gauge. AND cut the oil filter open and look for metal. Like B-Man said, it's better to just lift the engine out and do it on a stand. You're not so messy, not so irritated, don't kink your neck so badly, etc., etc. Besides, you need to check at least a couple rod bearings while you've got the pan off. And if you don't find any junk in the pump bypass, the engine has to come out anyway! In reality, it doesn't take much more time - if any. AND you can do a quick clean-off and shoot a nice, new coat of Pontiac blue on your engine. Pretty pretty again! |
Possibly Two seperate things going on here guys, the idle rpm reduction to 850 when hot could be fully responceable for the 20 psi now seen at idle , the unsteady pressure reading could just fully be the connection on the sender if it's electric , or the sender itself .
PSI
Yes I agreed tat dropping the idle rpm can drop psi at idle.
20 psi at idle is what I get in gear when motor is HOT and that's with 10W30. Jumps instantly as rpms go up. Gerry
1968 Firebird 400, 068 cam, TH400 & 13" Continental Converter, Auburn posi with 3:08 factory gears, Cliff's Q-jet resting on a 68 factory iron intake, DUI HEI and Ram Air pans and RARE Long Branch Manifolds |
Didn't get a bunch of fuel into the oil while working on the carbs did you? ... Can thin the oil out and cause a pressure drop.
Mine was working, but rapidly jittering. I don’t know if that is what yours is doing or a more slow fluctuation. I replaced the sender and cleaned up the electrical connector and it still does the same thing. Maybe the guage?
1979 TATA Extreme TKO .64 Hedman elite; Pypes 2.5; Borla XS; MSD 6A; Edelbrock intake; open scoop; Sniper Q-jet; Powermaster 150; 4 core radiator/Mark VIII fan; RobbMc mini starter; subframe connectors; solid body mounts; fiberglass rear springs; poly sway bar and link bushings; 81 master; D52’s; Blazer disks; 225/60 & 235/60 17's TrueContact's; relays for PW, PDL, lights; keyless entry |
After I pulled my motor and cleaned out the trash, I put the pump back on, hooked a pressure gauge up to the motor by the distributor (not the oil filter adapter), and submerged the oilpump pickup in a Tupperware type bowl of oil and I primed the motor to verify the problem was solved. My garage had a painted floor and I put some cardboard down because it's kinda messy but was well worth the piece of mind.
This ^^^^^^ mine was infantile metal chip from who knows where, pulled pump drove out check ball, honed passage with a wheel cylinder hone, car has 30k miles on it now, no issues
I had a similar problem with OP on the 79 TA. I dropped the pan removed the pump cleared the check ball and every thing turned out fine. I have since used the 9/16th balls and .060 shim to alleviate the problem. I have dropped the pan twice with no problems.
1979 Trans Am WS-6 .030 455 zero decked flat pistons 96 heads with SS valves 041 cam with Rhoads lifters 1.65 rockers RPM rods 800 Cliffs Q Jet on Holley Street Dominator ST-10 4 speed (3.42 first) w 2.73 rear gear __________________________________________________ _______________________________ 469th TFS Korat Thailand 1968-69 F-4E Muzzle 2 Last edited by track73; 04-11-2016 at 01:18 PM. Reason: typo |
Real oil pressure fluctuations are more gradual smooth up and downs a jittery gage is evidence of a indication problem..
If your not at the table you're on the menu A man who falls for everything stands for nothing. |
