Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 08-09-2016, 05:59 PM
541 goat 541 goat is offline
Default Wanted race Pistons 541 4.375 bore 4.5 stroke 1280 ch
Need set of Pistons or one or two. Anyone have any.
Old 08-09-2016, 07:09 PM
mysticmissle's Avatar
I have a set of diamonds just let me check ch. I know they were on 6.8 rods.
Old 08-09-2016, 09:05 PM
JD's Avatar
JD JD is offline
I have a set with 1.300" compression height.
Jim
71 Firebird, best 1/8th mile time of 5.02 at 142 at altitude in Vegas
Old 08-10-2016, 05:57 PM
Any info. on compression height
Old 08-10-2016, 06:37 PM
1.17 ch
Old 08-10-2016, 09:16 PM
What are the specs on these. ring size,grams.
Old 08-10-2016, 09:18 PM
You have 6.7 rods don't you
Old 08-10-2016, 09:19 PM
1.17 ch
Thank you for checking. Not sure if I want to buy new rods.
Old 08-10-2016, 09:20 PM
Yes,do you think they will work.
Old 08-11-2016, 06:30 AM
you will be .100 in the hole. not sure of your combo but NA i would think it is not optimum. If you have been decked alot you may not be the full .100 down though. lot of variables
Old 08-12-2016, 02:58 PM
JD's Avatar
JD JD is offline
They are CP pistons for Edelbrock heads. The tops and skirts are coated. Dome height is .16" with .305" intake valve relief and .285" exhaust valve relief. Compression height is 1.3. They were made for 4.375 bore. Piston size at .5" up from bottom of skirt is 4.37. Top ring is .043, second ring is 1/16, third ring is 3/16 plus support ring. Top ring is .330 down from top. Pistons have radial gas ports. Weight is 592 grams.
Jim
Old 08-12-2016, 06:10 PM
65nss4spdGTO's Avatar
65nss4spdGTO 65nss4spdGTO is offline
http://forums.maxperformanceinc.com/...d.php?t=725431
Calvin Hill
Hill Performance
708-250-7420
