Old 02-22-2017, 09:30 PM
*67firebird*'s Avatar
*67firebird* *67firebird* is offline
Send a message via AIM to *67firebird*
Default Living in NorCal, looking for temp work
Hi Everyone, im living in San Jose and I am waiting for a job to come my way, in the meantime im looking for temp work.
I am a Journeyman Electrician by trade, but can help with just about anything.
Let me know if you need any help,
Ozzy
Just wanted to add if you someone owns a shop like a welding,cnc, machine Im willing to volunteer my time if you can teach me some new skills.
463 Stroker Kit.
ross pistons. h beam rods. eagle crank.
62 heads 72cc, port matched
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 02-22-2017, 10:59 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Ozzy, wish you were in the Chicago area. I would have a bunch of small electrical jobs for you to help fill in the time. Good luck to you.
-Kevin
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
Old 02-23-2017, 10:18 AM
Thanks Kevin. I wish I was in Chicago too, I ate some of the best pizza and hot dogs ever when I took a vacation out there in 11'.
ID:	447937   Click image for larger version
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 02-23-2017, 10:20 AM
I just wanted to show my landscaping project. Took me 2 weeks by myself and waiting for a couple days of rain to go by.
I had to remove 10 yards of dirt/grass with a wheel barrel and shovel. Then lay down 9 yards of road base, compact it.8 yards of decomposed granite(deegee) and compact it 3 times. My friend did help me with removing the dirt/grass , but otherwise did it by myself. I bought some flat 1/8"x6"x10' steel and bent them at 90 degrees and welded them together to make my small faux retaining wall.
I will never do this kind of project for someone on my own, I would rent some equipment or get some day laborers! My back was sore for days, that's another reason why it took 2 weeks. I had to do a couple half days cause of my soreness.
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 02-23-2017, 11:31 AM
1965gp 1965gp is offline
That is quite the change!
Old 02-23-2017, 11:33 AM
I made this bench a couple years ago.
Gave my kitchen a facelift, removed the ugly pink and white tile and pink sink. stripped my cabinets and painted them. installed brushed nickel knobs and hinges. installed white subway tile and an Ikea butcher block counter top.
The more i look back at the work i've done, the more i feel handy. Show me the projects you need help with.
Name:	2015-08-23 12.04.19.jpg
ID:	447939   Click image for larger version
Name:	2015-08-02 16.36.14.jpg
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 02-23-2017, 12:10 PM
Anyone have switchgear they need terminated? HIGH VOLTAGE JUNKIE!
Name:	2015-09-10 09.48.07.jpg
ID:	447941   Click image for larger version
Name:	2015-09-23 07.57.30.jpg
ID:	447942   Click image for larger version
Name:	2015-09-02 11.56.29.jpg
463 Stroker Kit.
Performer RPM-850DP
Auburn- 3.55 gear
CC HR custom grind
Old 02-25-2017, 02:09 AM
post toastie's Avatar
https://sfbay.craigslist.org/sby/trd/6018577780.html just saw this tonite
