Flex plate bolts
Where can I get flex plate bolts like the originals with the short head ? I bought some ARP bolts but the head touches my torque converter. I got some Mr Gasket bolts with the thin head but they are too long, they are listed as flywheel bolts.
The guys here, collectively, probably have hundreds of decent originals. And they can be shipped cheap, thru the US Mail.
thepontiacman problably has a few dozen or more, himself. When I still had my shop, I had a gallon can or jug that was probably half full of 'em. I kept all the Pontiac engine bolts, in separate containers, so I could find 'em easily, when needed. There are probably quite a few guys here who do the same, now. Last edited by ponyakr; 03-12-2017 at 06:13 PM. |
If you still have the flywheel bolts, you could cut them down to size.
Just try not to overheat the bolt while cutting. Or as ponyakr says, someone probably has some they could send you.
What's the best way to cut a grade 8 bolt?
If anyone has a good set of bolts I would buy them
I just ordered a set from our host.
It's not the thread length it is head thickness.
I ran into the same problem with ARP. |
The bolts are longer for them. He could cut them to the correct size as the flexplate bolts, and still have the short height head. Quote:
A regular hacksaw would probably work also. Best to put a nut on it first before cutting. That way the thread on cut end won't be too bad once nut is unscrewed. (and probably be a good heat sink)
Hi
I have a set of originals I can ship out tomorrow
pics later tonite Scott off a 70 350 w t 350 |
Let me know what you want for them
Did you get them yet ? The pic in the catalog looks like a regular thick head on the bolt.
bolts
Hi
here is a set of bolts from a 73 455 in picture 2 I have the bolt screwed all the way in ... look at thenext hole down you can see 2 dirty threads .... thats the depth with flex plate on ... ALL have exc threads and corners on the bolts ... NO rolled edges ... nice set ... Scott scott68gto@comcast.net for more info thanks |
no, the parts have not arrived. bt
I have loads of originals I'll send a set. Sent you a PM Scott
