71 Turn Signal Switch Help
Guys,
I have purchased several different turn signal switches for my 71 however each of the new switches only have 10 pins in the connector but according to the Service manual and visually checking my under dash harness there are 11 wires/leads in the dash harness connector which it plugs into . (Pics Below) The 11th lead is a gray wire which ties into the illumination bundle of the harness. (Radio, Dash, etc lighting). I was curious if anyone else had experienced this issue, I do not have my original turn signal switch to compare. So before I install this into the column/car thought you guys may have some insight.. Thanks in Advance Larry
I Bleed Arrowhead Red, 64 GTO 389 Tri Power 4spd Nocturne Blue Poly 70 GTO 400 4spd Palladium Silver 70 GP 400/4 spd triple Black 71 T/A 455 4spd Cameo White 01 T/A Bright Red 4L60E Ram Air WS6 02 TA Navy Blue Metalic 6 spd Ram Air WS6 |
Your T/A is a 4 speed car, right? The gray wire is for the Shift Indicator light on a Column shift Firebird/Trans Am. ( yes I have seen one )
Ignore the gray wire..
1997938 is the correct switch
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
