Old 04-24-2017, 09:23 PM
Stickman77 Stickman77 is offline
Default 65 grand prix 10dn to 10si
Has anybody done a 10dn to 10si conversion on their 65 grand prix. Mine has the ammeter and 2 wire voltage regulator. Not sure how to do this conversion with my setup. Thanks
Old 04-25-2017, 08:58 AM
AROWHED's Avatar
AROWHED AROWHED is offline
Send a message via Yahoo to AROWHED
If I recall correctly all you need to do is attach the main wire to back of 10SI as normal, then add a wire jumper from that to #2 terminal of alternator's plug-in connector. You can also wire a charge light if needed from #1. Unplug connector at the old voltage regulator and wrap it up for protection.
Name:	the-delco-10-si-and-12-si-alternators-wiring-diagram-for-delco-alternator-series-10-si-and-serie.jpg
Red\black 65 Grand Prix 467 E-head stroker, Viper T-56 6-speed, 4.10 spool
Old 04-26-2017, 07:53 PM
LASJayhawk's Avatar
LASJayhawk LASJayhawk is offline
The current shunt for the meter is a tap in the wiring where it runs along the intake. The ammeter won't care what alternator you use, it will work as normal.
65 Bonneville Brougham 4DHT
65 Grand Prix 2DHT......now parts
65 Catalina 2+2 2DHT
65 Catalina Safari 4DSW
Old 04-27-2017, 01:28 PM
63gpman's Avatar
63gpman 63gpman is offline
I was wondering about this myself. So with our cars only having 2 wires at the regulator, we simply unplug it? No jumper there like on the 3 wire ones?
Brad Hansen
65 Cat Ventura, 66 Cat Vert, 63 GP
Old 04-28-2017, 01:38 PM
AROWHED's Avatar
Right, nothing else (but the jumper at alternator output to Term #2) is needed. The field wire from old regulator is no longer required...and the other wire to regulator was simply ignition-switched power to it. Like LAS noted, the ammeter shunt already i nthe wiring harness delivers the charging current to battery.
Name:	wiring-diagrams-of-1965-pontiac-catalina-star-chief-bonneville-and-grand-prix-part-2.jpg
Old 04-28-2017, 02:30 PM
Where is the shunt in the harness located?
Old 04-28-2017, 09:29 PM
LASJayhawk's Avatar
They just use the wire itself as the shunt, it's not a separate part.
