Old 08-14-2017, 11:03 AM
Speargun's Avatar
Speargun Speargun is offline
Default Which Pontiac block is this?
I just had a chance to take a quick look at a short block, but it didn't have the size embossed below the #1 cylinder or in the valley. What could it be?
Oil & dirt covered the back by the distributor hole and I couldn't get to the front of the block to check for numbers. There was no timing cover so I don't know if it was an 8 or 11 bolt.
There was a set of 061 ('67 400) & 7M5 ('72 455) heads sitting next to it, but I doubt either set was the original heads.
No!
Do not try!
Do! Or do not.
There is no try. - Yoda
1967 Firebird Restoration 2005 - 1/25/2017
Old 08-14-2017, 01:23 PM
ponyakr's Avatar
ponyakr ponyakr is offline
Wow, that's not much info to go by.
Since you said the heads are by, and not bolted to it, I suppose you could measure the cylinder bore. Should make it easy to ID it as a 326, 350, or something bigger. The 326 & 350 have a bore size less than 4 inches. Stock bore 389 & 421 were just barely over 4". 400 & 428 were nearly 4 1/8" @ 4.120. 455 was about 4.150.
Also, look at the sides of the block. If there are only 2 motor mount bolt holes, it came in a '69 or earlier model car. If it has only 2 freeze plugs, on the sides, that will help narrow down the possible year models it could be. '67 & later blocks have 3 freeze plugs, on each side. Earlier engines have only 2.
http://pontiachunters.com/articles/p...dentification/
But, obviously, the block casting number and date code, would really help narrow it down, a lot.
Old 08-14-2017, 02:02 PM
77 TRASHCAN's Avatar
[QUOTE=Speargun;5774108]I just had a chance to take a quick look at a short block, but it didn't have the size embossed below the #1 cylinder or in the valley. What could it be?
What color was the dirt?
Shut it off
Shut it off
Old 08-14-2017, 02:31 PM
Speargun's Avatar
I thought that all of the blocks had the last 2 digits of the engine size embossed on the side & in the valley. I've never seen a Pontiac block without it.
Hopefully I'll get a chance to check it out a little better tomorrow.
No!
Do not try!
Do! Or do not.
Old 08-14-2017, 02:55 PM
ponyakr's Avatar
Originally Posted by Speargun View Post
I thought that all of the blocks had the last 2 digits of the engine size embossed on the side & in the valley. I've never seen a Pontiac block without it...
The older blocks did not have the cubic inch numbers.
Also, the '78-'79 XX481988 blocks had XX in the lifter valley, instead of 00.
This info & a lot more is included in the link I posted. I think it will answer most of your questions. Here's the link again.
Old 08-14-2017, 03:53 PM
Stuart's Avatar
Stuart Stuart is offline
Get the block code and number off the front of the block.
Old 08-14-2017, 04:21 PM
ponyakr's Avatar
Info found on the front of the block may not help very much, by itself, since the same block code was sometimes used on different size engines, in different years.
For example: The YA code was used on 350, 389, 400, & 455 engines, from '65-'78.
http://www.wallaceracing.com/enginesearch4.htm
So, you'd at least need the date code, preferably the casting number and date code, to go along with the block code.
Old 08-14-2017, 07:34 PM
Simple Man's Avatar
Oh, that's one of those. Haven't seen one of those in years.....
be a simple...kinda man.
Old 08-14-2017, 08:43 PM
242177P's Avatar
242177P 242177P is offline
Pyramid (or lack of) and the number of motor mount holes...
Old 08-14-2017, 09:33 PM
tom s tom s is offline
The transfer lug would only tell you if it was non 389-400 block!350s and I think 326 got them along with the 3 1/4 main blocks.It is a good start along with the freeze plugs to tell what it might not be.Tom
Old 08-15-2017, 02:19 PM
Speargun's Avatar
I got another quick look at it today and found the engine code. It's an XV block.
It looks like it's a '67, 290hp, 400, 10.5 cr, & the 061 heads would be correct for that engine. I'll be picking it up tomorrow!
No!
Do not try!
Do! Or do not.
Old 08-15-2017, 03:45 PM
geeteeohguy's Avatar
My first car ('66 GTO) had a junkyard '67 XV engine in it, with the 061 heads. With a tripower, 4 speed, and 3.55 gears, that car ran like a scalded cat. The 061 is the first Pontiac non-closed chamber head, and a pretty good choice for today's builds. I found that out about a week after I scrapped my pair.
Jeff
Old 08-15-2017, 04:02 PM
ponyakr's Avatar
The XV code was also used on a '70 400 330hp 4-barrel engine, according to the Wallace ID page.
Easy way to tell which it is by the number of motor mount bolt holes. '67 only has 2. '70 has 5.
These sites also show an XV code on a '73 X-body 350 engine. Again, it would have 5 motor mount bolt holes.
http://www.pontiacpower.net/numbers/engine-codes/
http://www.classicalpontiac.com/cgi-...bal/engine.cgi
http://pontiachunters.com/pontiac_v8_engine_codes.shtml
Old 08-15-2017, 07:49 PM
PunchT37's Avatar
PunchT37 PunchT37 is offline
The `70 would have the CID identifier on it. So, it`s prolly the `67 engine. Also, 3 freeze plugs instead of 2.
Old 08-17-2017, 07:37 PM
Speargun's Avatar
I picked up the engine yesterday and it is a '67 400 with the 061 heads. It all needs cleaned up, but otherwise, everything looks good.
I'm going to clean it up, oil it down, & bag it for now. Maybe someday I (or some one else) may need it for a correct restoration.
No!
Do not try!
Do! Or do not.
Old 08-17-2017, 07:58 PM
PunchT37's Avatar
Good deal. Most say it`s the best 400 block.
Old 08-21-2017, 11:30 PM
cuz68's Avatar
cuz68 cuz68 is offline
My guess is a 1767 400.
Cuz68
Old 08-21-2017, 11:47 PM
Will Will is offline
Some people say the wide, shallow chambers don't have enough quench pad and are prone to detonation.
I know that I had detonation damage on the rod bearings of my 440" engine using those heads but I had also run the timing too far advanced because the curve was too long and the engine liked more initial.
At the track the car ran the same at 32-34 degrees total as it did with any more than that and I ended up running it about 36-38 for awhile because it really responded well to having 16-18 initial. Obviously I should've stuck to 32-34...
Trying to decide what to do with those heads. They have a really nice SD Performance port job (270+ cfm @ .550"). Wondering how they'd run if I put them on a 350...
