#61
I'm well thanks, you? I would think the TKO 5-speed with the .82 OD would suit my needs, no? 2.87 x 3.42 = 9.82 for 1st gear. Too much or is that ok? With .82 and 3.42 and 26" tires that's 1,993RPM @ 55 (vs 2,650 today), and 2,356 RPM @ 65. MUCH better than I'm currently at. FYI: at .64 OD that's 1,556 RPM @ 55 MPH and 1,839 @ 65. Hmm, maybe the .64 would be better. I would LOVE to cruise at 1,800 RPM and actually get somewhere in a reasonable amount of time. What 6spd fits our engines, they seem to be for LS motors? Oh, and I don't mind hacking the poop out of my floor to make it fit. It's a clone and I have no center console to worry about. I just want a nice finished product that drives well and can handle the abuse.
Adam __________________ 1964 LeGTO 469, M21, 3.42 __________________ Sold: 1968 Pontiac LeMans Convertible See it go HERE |
#62
I have 66 GTO with tko 6 speed, 27 1/2 rear tire, 390 gears. Have 5 thousand miles on car. Car runs and performs fantastic, wouldn't change a thing.
#63
We are doing fine and getting ready for Christmas, Dale
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot |
#64
Agree with Highrisk. I much rather prefer the .64. As expensive as these swaps can be for an overdrive, I want an OVERDRIVE. .82 just isn't much, I'm not paying $3,000 to $4,000 for just a 20-21% in rpm reduction. Rather just live with a 4 gear.
I'd recommend the .64 and get the most for your money. As an example, I've run a couple of T-56 6-speeds. 5th was a .74 and even that wasn't really a big drop. 6th was .50 and loved it. Quite honestly I found 5th gear a waste and never really used it, skipped it most of the time driving. In my opinion the 6 gears aren't needed. GM could have made that a 5 speed and I'd have been happy. Now they are making the 6 speed with a .80 5th, that's even worse. I just need 4 forward gears and one overdrive. Last edited by Formulajones; 12-06-2017 at 03:14 PM. |
#65
I am running 3.42 gears in my 66 GTO with a 461 Stroker that makes 450 HP & 500 Lb/Ft at the rear wheels. I cruise at 70 with 1950 rpm and 255X60-15 (27 inch)tires in the rear. I like the combo.
#66
I just am thinking about dollars spent/ vs MPG gain. I may drive my car 500 miles in a year. So I think if you drove your car 10000 miles at 15 mpg @ 2.50 per gallon and now after spending maybe $4000 on a OD trans, now you get 20 mpg. Your fuel cost would be 1666.00 @ 15 mpg and 1250.00 @ 20 mpg. So thats $625 savings for every 10000 miles driven. So you would maybe have to drive 32000 miles just to break even....if you actually got the 5 mpg gasoline savings. I dont even know my actual MPG, I really dont want to know, and I dont care. So I would not consider it unless you have a cruiser and put more than 10000 miles per year. ; )
1968 Firebird 400 RAII M21, 3.31 12 bolt, Mayfair Maize. 1977 Trans Am W72 400, TH350, 3.23 T Top Everyone you will ever meet knows something you don't. Bill Nye. |
#67
But It really isn't too bad right now as I'm so close the the original setup the car came with (3.23's which nets an 8.26) running 26.7" or 27.1" tires (recently switched to 17's) when I was running the 389, but now am running a 462. With the current 26.7" tires at 70 I'm cruising at 2700 - much better than 3000. And I can still run my original Hurst shifter and console... |
#68
Dale
#69
.64 and a 3:73 here. 455 with a 230/236 on a 110 cam
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
#70
I kind of cheated with the shifter. In December 2007 we had a house fire that destroyed my 66 GTO. For some reason I kept the shifter. I took the shifter apart and took out the shifter arm then cut and ground on it until it matched the attachment point on the 5 speed shifter and drilled two holes. I also use the stock 4 speed shifter ball so it really does look like I have an original Hurst shifter in the car. You have to excuse the Hurst shifter boot, the original 65 boot would not cover the 5 speed shifter.
Below is before and after of the 66. Very sad day. Dale
#71
I don't concern myself too much with the MPG increases, mine do pretty darn good without an overdrive, but the engine working less, less wear and tear, less noise, is pretty nice. I don't recommend OD's for some. I've done 3 swaps for a fella in 3 of his cars. I did the last one about 2 years ago. He doesn't drive any of them any further than 4 blocks to the local cruise. Really a waste of money in that instance, should have just left the 4 speeds in them. Guys that really enjoy the cars, and I mean a "real" car guy that actually drives these things, the OD's are pretty sweet. |
#74
Yep. These cars can be pretty darn decent on fuel if tuned properly, and a combination that all works happy together. So MPG for us isn't the first thought when considering an OD.
#75
#76
Here our speed limit is 75 mph. Most go much faster. Now myself, I'm happy going 65 mph, maybe 70. 65 mph in most of our cars is 2800-ish rpm (no overdrive) So not a big deal. Our bigger cruise inns here are a 200 mile round trip for us to attend. I've been doing that for over 10 years, and there is no winter break here, we cruise year round. So in my case the cars could benefit from an OD. Can't afford to do them all, but may do one for myself one of these days. I've done 4,000 mile cross country trips like this and I'm okay with it (65 mph at 2800 rpm) |
#77
Yea, but when I'm doing 45 MPH, it's SOOO much more enjoyable inside to have a conversation and to not be worried about the higher RPM's.
#78
My favorite show is a 230 mile drive one way with a mix of Interstate and 2 lane roads. Dropping 300 RPM by doing the gear swap really made me feel a lot better on the Interstate sections. In cruising mode - I can pull about 18 MPG with the 462.
After I retire (Feb 2019), I may do an EFI conversion to help with driveability on longer distance cruises with varying altitudes. If it helps out the mileage a little, fine, but not that important to me. |
#79
If you liked a 300 rpm drop, you would really enjoy nearly a 1,000 rpm drop with a .64 overdrive.
#80
With my 3.36s im about 1900-2000 right at 70.Will turn Waze on next time I drive it to be exact.Tom
