1963 Pontiac 421 S.D. Super Duty Catalina heads 980 cast 9771980 RARE - $2750
I have an extremely RARE pair of 1962/1963 Pontiac Catalina Super Duty cylinder heads. They are referred to as '980s' with a full part number of 9771980.
If you know Pontiacs you know that these are some of the most sought after FACTORY vintage race heads used on the infamous early 421 Super Duty Motors. Of course the dual quad or 2 - 4bbl. being the most desirable race version. These heads were superceded by the 544127 or '127' Super Duty heads in October of 1962. All 421 Super Duty motors were discontinued by January of 1963 although some Catalina S.D.'s were built until April of 1963. These particular heads have been O ringed (Affects absolutely nothing) and knife edged back in the day by a VERY qualified Pontiac racer. I just had them magged and there are NO cracks present. Grab these rare heads while you can. You may NEVER see another pair of these! Text or call me. Thanks! $2750.00. Four One Four - 807- Zero Seven 27. |
Anything to go with them like guide plates,valves or rockers?Factory rockers are impossible to find.Tom
Tom, I have some things but at this time it is just this set of heads bare.
Tom I have a set of 127 guide plates. DK if they are the same as for 980s.
I have seen knife edged cranks before. Looks like a good buy.
WWW.GLASGOPERFORMANCE.COM. Updated... Sort of! |
Fabcraft sells the guide plates.Tom
Do these heads already have the center exhaust ports separated, or are they Siamesed like "normal" heads.
Are the rocker studs screwed in or pinned. It looks like one is broken off.
BONESTOCK GOATS '64 GTO Tripower Hardtop (Wife's Car) '64 GTO Tripower Post Coupe (My Car) '99 Bonneville SE Sedan |
Any pic of the intake ports?Flo sheet?Any idea of who ported them?Have a guy looking for a good set.Tom
Hi Tom. I can give you more detailed info if you want to call me. Thanks, Jeff
Very tempting! Ported to the max, any history on these rare bits?
DragStarLeMans |
Factory studs are pressed in and pinned.As I remember the stud boss needs to be milled to use screwin studs.I think 61-63 has done the swap.Also remember it takes a diff header as the center exhaust bolts are set wider than any other D port head.They are a good buy IMO.Tom
