Radio/Speaker/Antenna Diagnosis
Hi folks,
I am writing a series of articles to help folks figure out what components of a car's audio system works and how to test it without wasting time or money doing so. Here is part 1 of the series... https://redirad.com/blogs/news/colle...eration-part-1 Please read it and share with friends. I will post subsequent parts of the series as replies to this post. If you find any typos, send me a Private Message. thanks! |
Keep it coming Matt, I can use all the help you can provide on this subject.
Doing good Matt!
Good read so far, I like it!!
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
Thanks for the encouragement, guys.
I should have part 2 uploaded late this week. |
Yep ... just pulled apart my original 68 AM radio for a look-see. Don't have an 8-10 ohm speaker for testing as yet (and I noticed an original sticker on the radio that said not to even turn it on without the speaker attached), also I need an old school radio antenna hook up to use with it.
Only problems I found was the pre-set mechanism which was solved with some light sewing machine oil on the little "slip clutch" thingie. And the tiny copper wire from the plastic coil to the antenna socked was broken so I had to resolder that. Would love to see some info on testing the systems. |
Yepper. https://www.bestbuy.com/site/metra-a...=ref:212,loc:2 Quote:
If you don't have a 12VDC power supply, you can use a spare car or cycle battery. Don't use a battery charger! |
Found the antenna on Amazon also, so bought it along with the speaker.
I've got a variable 0-30 vdc 10 amp power supply, typical adjustable voltage and current lab type power supply (can set to constant voltage or constant current), figured I would use that. Would be a ton of fun to hear sounds coming out of that thing for the first time since 40 years ago. Unit seems pretty clean and corrosion free, no obviously burnt out components, light bulb even still worked (different circuit than the radio). Any chance you have a 60's era Pontiac AM radio on hand where you could point out the proper connections at the rear plug? They are labeled ... but the power in and the speaker out location seems kind of ambiguous. Don't want to fry anything by hooking it up wrong. I assume single wire to speaker with a local ground? Thanks for the links, I'll post back in a few days after they show up and I can test it. |
Here you go...
Connection description...
Rock on! |
Thank you. I'll have the speaker and antenna in tomorrow .... see if I can get some sounds out of this thing.
Success! Took a bit of fiddling with the volume pot to get some sound out of the speaker, but with continued use it got better and less crackling. Brought in three or four stations with the antenna just hanging from a shelf and the whole thing in my basement shop.
This is a standard AM radio with front and rear speaker. The volume pot is a dual type correct? The white plastic sleeve around the shaft controls tone? Worst case scenario I have to replace the volume/tone pot ... doable? Available? While I might be able to find the same rated pot ... doubt I could find the right shaft configuration unless a vintage radio place stocks them. It works tolerably well now .... seems to get better with use. And I just want the radio to work for restoration purposes, it will not be used as an actual entertainment device My GTO original had a switch tucked underneath the upper dash (like where the electric antenna control would go) which I think was a fader to the rear speaker ... am I remembering right? Since there is only one "speaker out" connection on the radio I assume the harness had a splitter and one ran to the front, and one ran through the fader to the rear, or the main speaker out ran to the fader and the fader had one out to the front and one out to the rear .... I can look it up I guess. So, Engine-Ear, thanks for the help. Seems to work pretty good, power transistor got a little warm, but from the size of the sink I assume that's normal. Wonder if that's replaceable too. BTW ... this radio is in pretty much exact original condition ... looks like it's five years old. Still has the little stickers and such on it if anyone is curious about the minutia of such things. |
Some fresh heat-sink compound might help.
Greg Reid Palmetto, Georgia |
Yep, good idea.
The Eagle has landed...
Yes, on the left shaft. Quote:
Never looked (don't have part numbers to search by) - If NOS ones are, please let me know. Quote:
LOL, well it is YOUR car... Quote:
Part 2 of the article series will be posted to "Matt's Madness" this weekend. Please post the model and serial number that's on the paper label...and maybe a pic or two? |
Attached are pics of the serial number/patent label and two pics of factory inspection marks ( I think ).
Any chance a pot wiper can be cleaned with electrical contact cleaner without opening it up? |
PLUS, not all contact cleaners are created equally, and some will damage the resistive material (chemical interaction). When I disassemble one of these, I use 99% Iso-Propyl Alcohol and industrial swabs (Q-tips on a wooden stick that don't get frizzy) and wipe them until the swabs are clean. I then burnish the sprung brass contacts and give them a SLIGHT bend for added contact force when they go back together. Pics show what's inside... |
...basically the same unit I just finished for my dad's '68 Catalina (different model number and cast dash-interface plate) but electrically the same. Here is his...
Don't know if this is a good foundation for a redirad or something. Otherwise I'll disconnect it and hide a modern radio somewhere with modern CustomAutoSound speakers under the front seats. Verstuurd vanaf mijn SM-T585 met Tapatalk
'67 GTO hardtop coupe 400 2bbl (sporting a 4 bbl) '70 GTO convertible 400/400, matching numbers, Currently getting worked on again, body in the bodyshop, engine at the machine shop etc!!) '71 LeMans Sport T41 Coupe restomod (GTO clone with Judge stripes and wing) 400/350 '71 LeMans Woody Wagon 400/350 patina project 1975 Grand Am 400 factory sunroof project car |
Sorry to sound like an advertisement, but...
If you're hearing crackling, the speaker probably should be renewed, and radio may need an electrical cleaning and adjustment. ...Not surprising for something that's > 40 years old (and not expensive, either). If your car is STOCK (not a pro-touring, etc. car), for the first time, you can port music from your phone or MP3 thru that radio, without the cutting, drilling or the added cost for something aftermarket. It is also my understanding that folks there pay EXTRA auto insurance if the radio in an "oldtimer" is aftermarket. If so, ANOTHER reason to consider RediRad. Quote:
Send me a private message if you want more information. You can also check out RediRad .com for info, or YouTube for some videos. Good luck with your decision... |
Never though about the AM signal being gone since I can listen AM radio in my company car if I want.
So I checked the situation again today. I think the radio might be ok, I only hear the crackling when I'm fiddling with the volume or frequency knobs. Btw insurance here doesn't really care or make any difference if a car is modified or not. This might be a good redirad starting point. Erik
