Old 03-25-2018, 02:28 PM
Green Hornet's Avatar
Green Hornet Green Hornet is offline
loaded 'puff.
Not my choice of colors......but prolly the best original 72 Esprit stick......on the planet....Looks like a full load.....even has a posi...
https://www.cars-on-line.com/gen3-ca.../posting/93785
  #402
Old 03-25-2018, 02:30 PM
RamAir's Avatar
RamAir RamAir is offline
Originally Posted by Green Hornet View Post
loaded 'puff.
That exhaust though
  #403
Old 03-25-2018, 04:47 PM
Dang, what a well optioned car! I love everything about it, except the price.
loaded 'puff.
  #404
Old 03-25-2018, 05:31 PM
"Front Bumper Panel" wonder what that is?
(on window sticker)
Steel valence instead of plastic?
  #405
Old 03-25-2018, 05:48 PM
blue71ta's Avatar
blue71ta blue71ta is offline
my thoughts exactly
  #406
Old 03-25-2018, 07:21 PM
Norwood's Avatar
Norwood Norwood is offline
Original paint and clear coat? Repop steering wheel?
  #407
Old 03-25-2018, 09:30 PM
Very cool car...
But I agree -- at that asking price, I haven't wasted any time looking to see how far of a drive it might be to Freeport, IL
  #408
Old 03-25-2018, 10:11 PM
375 miles, 5 hours 47 minutes...
Very cool car...
  #409
Old 03-25-2018, 11:23 PM
Transamric's Avatar
(on window sticker)
Can't be that. The car has a plastic valance panel. Copy the front end pic & blow it up a bit. Clearly not a steel piece.
  #410
Old 03-25-2018, 11:48 PM
Maybe the plastic filler panel between the core support and the bumper? Just a guess.
(on window sticker)
Name:	Rad filler.JPG
  #411
Old 03-26-2018, 07:37 AM
That could be it.
I never noticed it as a separate listing, thought it was included in the AC option. It is no charge though, so just spelled out more on the sheet.
  #412
Old 03-26-2018, 08:01 AM
bossbirdta's Avatar
bossbirdta bossbirdta is offline
...wonder what the mysterious third lever is on the steering column?...some sort of aftermarket cruse control??... also noted possible power antenna on drivers fender and ziebart plugs in jambs..
awesome car nonetheless...
  #413
Old 03-26-2018, 01:24 PM
bird72's Avatar
bird72 bird72 is offline
That is an unusual order one for sure. Same money with a couple less options would get a F400 when new. A tach to monitor a 7.7 to 1, 2V, single exhaust 350 is, well, different. That would be a great car for a build platform, but not at nice F400 price. Tranny would be Saginaw.
Being the Esprit guy, I look for the little tidbits. while not saying bad news , they make one look deeper.
The 350 emblem in grille under Pontiac is gone.
My trunk bird is solid red all middle and original. This looks 73 style......
Norwood said on wheel..........
Exhaust downturn would be cut to stick gaudy tip on.
Dash vent chrome is kinda bad for 20K
Just saying, not putting down car.
Cruise control on 4 speed? It is ticky tacky on turn signal, that must be annoying.
72 Bird
  #414
Old 03-26-2018, 01:49 PM
Formulabruce's Avatar
The Filler panel was ordered. It was no cost and some dealerships had them in the parts room and put them on cars under warranty with cooling issues. I have one on a NON AC car and it really works well.
Rare to see it on a Window sticker. On a 1970 Core support, the top plate is pre drilled for these. Since the top plate area where it mounts is 2 sheets of metal a tech still needed to drill the bottom plate. This made it fit perfect and went on fast.
  #415
Old 03-26-2018, 08:55 PM
Transamric's Avatar
That Bumper Panel "option" is Sales Code 901 which I do not find a reference to anywhere. But usually the three digit number codes referred to paint and/or trim colors. For an example, code 901 for '74 Firebirds indicated Red Morrokide interior trim. obviously not the case with this '72.
But let's not put too much stake in that window sticker being a correct original. '72 was a bit tricky year since there was a mid production change in window sticker forms. The early form was very similar to the '71 form and the late '72 was a close match to the '73 form with red across the top. If Mike Noun sees this, hopefully he will chime in with his (superior) knowledge & experience on this. To me, it appears this Esprit with a partial VIN of N5314xx (not all readable) would make this one of the last '72 Firebirds built before the Norwood strike, which started April 7th (a Friday). I've found very few 04A '72's and nothing later. So I'd say this Esprit should have the late '72 W.S. form, making the one pictured a repro not of Mike Nouns making.
  #416
Old 03-26-2018, 09:11 PM
Bentwheelbob's Avatar
Better yet, I would love to see the PHS. This is a pretty cool car. If this weren’t an Esprit the total options would challenge mine for total options. Regardless, it looks to be in great condition, although no underhood or underbody pics are provided. I’d love to have this car for $20k..
  #417
Old 04-06-2018, 11:41 AM
oldsmobiledave oldsmobiledave is offline
Default Cream Puff
Cream Puff
https://www.ebay.com/itm/1971-Pontia...hawYFQ&vxp=mtr
Own many Olds including
1972 442 W-30 (last 4 speed W-30 built);
1970 Cutlass W-31 #s match auto 3.91s;
1965 442 461 cid BBO & Richmond 5 speed;
1987 442 with 470 cid SBO 11.37 @ 119.4;
1972 442 524 cid BBO race car 10.89 @ 122.5;
1973 442 350 automatic black & white;
1980 GMC 468 cid BBO powered.
Past owner of an original paint 1973 Esprit.
Looking for the keeper 1970-1974 Pontiac F body.
  #418
Old 04-06-2018, 11:53 AM
OVERULD's Avatar
OVERULD OVERULD is offline
Nice car!
  #419
Old 04-06-2018, 01:49 PM
The Boss's Avatar
The Boss The Boss is offline
It's not a third member it's a wired cruise control fob connected to the turn lever.
That's a really nice car!
And go racin' in the street.
  #420
Old 04-06-2018, 01:52 PM
Decent looking car.......but too much air.....in the rear springs....
At 10k.....I 'd say it's realistically priced.......
