#81
Trying to throw off AQ? |
#82
If bet it hooks on gravel too
#83
Probably a 326 with 2.73 gears and a 2 barrel.... I believe you Paul...lol my old 10 sec car used to beat 9 second cars too.... strange math isn't it...
#84
Last time I weighed my formula it weighed 3800 pounds without me and 4000 with me.
The only thing missing from the factory is the air conditioning compressor ,spare tire and jack.
74 Formula 469, 6X-4's, 72 Intake, Ramair Manifolds. 3 inch exhaust with x-pipe Custom Roller Cam, 1.52 Roller Rockers Quadrajet done by Cliff 3:42 gears 12.075 @ 112.70 12.092 @ 112.43 12.128 @ 111.71 Last edited by form74; 09-20-2018 at 08:24 AM. |
#86
When I first weighed my 74 Firebird it was 3960 without a roll bar or driver. It had iron heads two batteries and two bottles. Now I've widdled it down to around 3650 with a roll bar but no driver.
#87
So went out to tnt again sat, weather was similar to last time out, a tad cooler but more humidity, anyway track wasn’t near as good as last time since it rained from Tuesday thru Thursday night! Had a issue with my tach acting up so I couldn’t shift where I did two weeks ago, short shifting it, car basically ran same Et with worse 60ft n more mph! Very pleased with the outcome considering everything n less gear now.
Darby 74 Grandville 2Dr 455 c.i 4550# 2011 1.60 60 ft,7.33@94.55-11.502@117.74 2017, 74 firebird -3600 lbs (all bests) 1.33 60 ft, 6.314@108.39 9.950@134.32 M/T 275/60 ET SS Drag Radial 2023,(Pontiac 505) 1.27 60 ft, 5.97@112.86, 9.48@139.31.... 275/60 Radial Pro's |
#88
With the tach screwed up were you able to see how much the rpm was reduced at the stripe? |
#89
Not Really, cause that's where it was screwing up the most when it got up around 6500, just start making jumps up damn near hitting 8 in second which obviously was then thinking i needed the rev limiter when it went past 7200, which the motor wasn't even close to that
