Old 11-25-2018, 10:49 AM
Slider Slider is offline
Default Drum to Disc - 65 Tempest - In-line Tube Kit
It’s been 2 long years since my dad passed and I brought home his 65 Tempest. The car has been garage kept its whole life with only 36k miles. The rear wheel cylinders were leaking so I replaced all rear brakes, hardware and axle lines, which took some tweaking to get them to fit.
I need to get the car out of the garage as I’m having the garage doors replaced so I decided that weekend I’d tackle the front disc conversion. Everything went fine until I got to removing the lower ball joint from the spindle. What a freaking nightmare that was. I ended up damaging the seal and then the threads so ended up replacing the ball joint also. Took a lot of heat and 5 lb sledge to finally get it free after 3+ hours.
Hind sight I would have opted for the Scarebird kit as the inline (or other spindle kits) are not much more than the same thing, a bracket that bolts to the spindle. I don’t have a hoist so the car is up on jack stands and replacing ball joints down on the ground is a total PITA. Not to mention the extra $$ spent on ball joints, renting tool, buying more tools to try to remove the lower joint from spindle and added aggravation.
I finished up at 1:00am last night and still have drivers side to go, plus installing booster, master and plumbing it. But it was a moral victory to at least get one side done
ID:	498639   Click image for larger version
Old 11-25-2018, 02:52 PM
Chris65LeMans's Avatar
Looks good!
Old 11-26-2018, 07:47 AM
tempest1964's Avatar
Looks factory original. Very nice. Even if it is a PITA. Good job.
Old 12-14-2018, 12:08 AM
64speed's Avatar
64speed 64speed is offline
Make sure that ball joint is seated since you did it on the car. It’s hard to tell and can have disastrous results. I did the set on my car when I first got it and one seated and one didn’t. Drove to the alignment shop 2 miles away and made it by the grace of god because the passenger side was in cocked and about to come out
Old 12-14-2018, 12:16 AM
They appear to be seated all the way around but I’m going to take a better look before I wrap it all up
